Brake problem driving me crazy!, UPDATE PG2!!!!!!!!!!!! |
Apr 15, 2007 - 10:34 PM |
Enthusiast Joined Dec 13, '03 From Alabama Currently Offline Reputation: 1 (100%) |
Ok, I recently decided to replace my master cylinder in my car because A. There was a lack of pedal pressure and B. I could not get any fluid to bleed out of the front right or left rear brakes. After I replaced the master cylinder with a reman I am still having the same problem. I made sure to reinstall all gaskets and O-rings, and to properly bleed the master cylinder before install. I have gone as far as removing the proportioning valve to make sure it still worked properly and it did and had no clogs. So as it sits right now I have good pressure to the front left and right rear brakes but no pressure to the right front or left rear brakes.
The master cylinder is providing pressure to the proportioning valve as proved by removing the line at the prop valve. I also sprayed all of the lines with windex and tried to find a leak but have not been able to find one. also checked the lines for any kinks but found nothing. Any ideas? This post has been edited by Justin: May 6, 2007 - 12:58 AM |
Apr 16, 2007 - 10:48 PM |
Enthusiast Joined Nov 10, '06 From Cleveland Currently Offline Reputation: 0 (0%) |
You say you checked at the input to the proportioning valve, but did you check the outputs? The valve can get stuck and you will only get pressure on one side.
Apr 16, 2007 - 11:45 PM |
I blew through it and air passed through all ports
Apr 17, 2007 - 10:15 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(Justin @ Apr 15, 2007 - 10:34 PM) [snapback]547103[/snapback] Ok, I recently decided to replace my master cylinder in my car because A. There was a lack of pedal pressure and B. I could not get any fluid to bleed out of the front right or left rear brakes. After I replaced the master cylinder with a reman I am still having the same problem. I made sure to reinstall all gaskets and O-rings, and to properly bleed the master cylinder before install. I have gone as far as removing the proportioning valve to make sure it still worked properly and it did and had no clogs. So as it sits right now I have good pressure to the front left and right rear brakes but no pressure to the right front or left rear brakes. The master cylinder is providing pressure to the proportioning valve as proved by removing the line at the prop valve. I also sprayed all of the lines with windex and tried to find a leak but have not been able to find one. also checked the lines for any kinks but found nothing. Any ideas? Did you have someone stepping on the brakes while you open a bleeder valve? |
Apr 18, 2007 - 12:31 AM |
yes, i even bought a vacuum pump to bleed them. It works great on the two that have pressure but wont even pull any fluid at all out of the other two.
Apr 18, 2007 - 11:41 AM |
Do you have ABS?
Apr 18, 2007 - 5:08 PM |
QUOTE(jc47 @ Apr 18, 2007 - 11:41 AM) [snapback]548125[/snapback] Do you have ABS? If you dont have ABS I would guess that its another bad master cylinder. You did have the person in the car pump the petel, Hold it, then open the bleeder valve, Right? |
Apr 18, 2007 - 10:26 PM |
Yes I did. My dads friend is the service manager at the mitsubishi dealership so the car is going there tomorrow.
Apr 20, 2007 - 9:43 AM |
Well turns out the master cylinder I got is not good. Autozone FTL. And apparently this part is close to impossible to get anywhere else. Looks like ill be stuck driving our blazer thats leaking coolant like crazy and for some reason uses about 15 dollars a day in gas.
Apr 21, 2007 - 10:32 AM |
QUOTE(Justin @ Apr 20, 2007 - 9:43 AM) [snapback]548806[/snapback] Well turns out the master cylinder I got is not good. Autozone FTL. And apparently this part is close to impossible to get anywhere else. Looks like ill be stuck driving our blazer thats leaking coolant like crazy and for some reason uses about 15 dollars a day in gas. can you get one from toyota? |
Apr 22, 2007 - 11:09 PM |
Enthusiast Joined Nov 29, '03 From Auburn, ca Currently Offline Reputation: 0 (0%) |
or a recycling yard like T.A.P.
Apr 23, 2007 - 9:54 PM |
QUOTE(toyotacrazy @ Apr 21, 2007 - 10:32 AM) [snapback]549061[/snapback] QUOTE(Justin @ Apr 20, 2007 - 9:43 AM) [snapback]548806[/snapback] Well turns out the master cylinder I got is not good. Autozone FTL. And apparently this part is close to impossible to get anywhere else. Looks like ill be stuck driving our blazer thats leaking coolant like crazy and for some reason uses about 15 dollars a day in gas. can you get one from toyota? Exactly. This is why it's worth it to spend the extra $$ and buy OEM to begin with.... -------------------- |
Apr 23, 2007 - 9:57 PM |
well they got me an acdelco one the same day I took the car in and it works fine......for now at least.
Apr 23, 2007 - 10:47 PM |
AC Delco is a Toyota supplier now....
I don't know whether to be scared or glad. -------------------- |
Apr 24, 2007 - 12:32 AM |
QUOTE(alltracman78 @ Apr 23, 2007 - 10:47 PM) [snapback]549860[/snapback] AC Delco is a Toyota supplier now.... I don't know whether to be scared or glad. LOL its better than autozone (Fenco) atleast. My brake pedal still goes to far down. I've tried bleeding the brakes (properly) but that didnt really do anything. It seems as if when you first step on the pedal the front brakes bite but the rear doesn't engage until about halfway down. I think it could be that the rear shoes are worn so far that the brake cylinder has to travel so far. So I am going to have a look at that tomorrow. Is it also a possibility that the front calipers may not be good? I did get them from a junkyard when my stock ones were sticking. I think they are from a GT and I dont know if that makes a difference. They fit perfect and don't leak or stick. Any suggestions? |
Apr 24, 2007 - 5:11 AM |
QUOTE(Justin @ Apr 24, 2007 - 12:32 AM) [snapback]549883[/snapback] QUOTE(alltracman78 @ Apr 23, 2007 - 10:47 PM) [snapback]549860[/snapback] AC Delco is a Toyota supplier now.... I don't know whether to be scared or glad. LOL its better than autozone (Fenco) atleast. My brake pedal still goes to far down. I've tried bleeding the brakes (properly) but that didnt really do anything. It seems as if when you first step on the pedal the front brakes bite but the rear doesn't engage until about halfway down. I think it could be that the rear shoes are worn so far that the brake cylinder has to travel so far. So I am going to have a look at that tomorrow. Is it also a possibility that the front calipers may not be good? I did get them from a junkyard when my stock ones were sticking. I think they are from a GT and I dont know if that makes a difference. They fit perfect and don't leak or stick. Any suggestions? adjust out your rear shoes. Even a little bit of clearence can make a big difference. |
Apr 24, 2007 - 7:00 PM |
Ok so i replaced the rear shoes and adjusted them out and still no difference.
Apr 24, 2007 - 9:08 PM |
Enthusiast Joined Apr 24, '07 From lufkin tx Currently Offline Reputation: 0 (0%) |
What to do for spring setup on a 95 celica ST?
really what to do with the car just bought it ideas? already put 2.25" piping w/ magnaflow tip rims /tires |
Apr 25, 2007 - 1:33 PM |
QUOTE(Justin @ Apr 24, 2007 - 7:00 PM) [snapback]550247[/snapback] Ok so i replaced the rear shoes and adjusted them out and still no difference. how about the rear wheel cylinders, those should be changed as well since they probably leak and can acutally when worn suck air into the system! This post has been edited by Bitter: Apr 25, 2007 - 1:33 PM -------------------- |
Apr 25, 2007 - 7:19 PM |
Dude, don't just throw parts at it.
Check the wheel cylinders. It will be obvious if they are bad. A slight bit of dampness IS ok. If they are soaked, they are leaking. How far out did you adjust them? Ideally they should be adjusted out until you JUST hear the drum rub the shoes, then back off a notch or two. Did you check/adjust the booster push rod to master cyl clearance? There should be less than .5mm clearance. -------------------- |
Lo-Fi Version | Time is now: January 9th, 2025 - 1:15 PM |
