> Linkage Problems, As stated, Linkage clip keeps breaking on my Auto 94 GT
post Apr 17, 2007 - 7:36 PM
THCelica
Joined Jun 24, '06
From Memphis, TN USA
Had a new tranny put in and I have snapped 3 linkage clips now and the linkage has been adjusted twice.
What in the world would make the clips break?
post Apr 17, 2007 - 9:54 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(THCelica @ Apr 17, 2007 - 7:36 PM) [snapback]547848[/snapback]
Are you talking about the throttle linkage/cable to the transmission? What clips are you referring to?
post Apr 18, 2007 - 4:33 AM
THCelica
Joined Jun 24, '06
Shifter linkage. When these clips go the shifter gets all jacked up.
Apparently there is a clip in the shape of a D or similar that holds all the shifter cables together etc. And it keeps breaking.
This post has been edited by THCelica: Apr 18, 2007 - 4:34 AM
post Apr 18, 2007 - 7:18 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Actually it's in the shape of a "U" I don't know how it's breaking though it's pretty strong and springy. Do you have the ones that are broken that you could take a picture of? My bet is that they don't have the shifter cable on the bracket correctly or the wrong bracket is being used and that is causing the spring clip to pop out. Was the tranny from a celica or a camry?
post Apr 18, 2007 - 12:08 PM
THCelica
Joined Jun 24, '06
Well I was close when I said "D". Anyways. That is a good question. I am not a hundred percent whether it was from a Celica or not. It may be the Camry's. It is the A140E that is in there I believe. Or I could be wrong. But tell me more about this bracket thing.
And then I wonder, can this be cause by something internal?
Lo-Fi Version Time is now: November 26th, 2024 - 12:45 PM
