st185 exhaust manifold, manifold swap |
Apr 18, 2007 - 2:27 PM |
Enthusiast Joined May 24, '05 From Malta Currently Offline Reputation: 0 (0%) |
quick question, will an st185 manifold fit an a leter gen 3s-gte?
Apr 18, 2007 - 2:41 PM |
Enthusiast Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) |
Not 3rd or 4th gen. i believe it will fit 2nd tho.
Apr 18, 2007 - 2:46 PM |
st185 is gen2. so no, it wont fit later gens.
Apr 18, 2007 - 2:47 PM |
Duh - I read ST-165. Must have been from that OT topic.
Apr 18, 2007 - 2:48 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
Exhaust manifold comparison:
-------------------- _Gary
Apr 18, 2007 - 3:31 PM |
Enthusiast Joined Jan 29, '07 From Hoyt Lakes, MN Currently Offline Reputation: 11 (100%) |
It seems to me like all the bolt patterns are different. If this is the case, how will any of the 3sgte manifolds fit the 5sfe?
-------------------- 98 Celica gt red- totaled deer
94 Celica st black DD (bad weather beater)- totaled deer 95 Celica gt silver- chassis sold 88 Celica All-Trac (Burned to a crisp) 94 Celica gt white (sold) In need of a rust free chassis!!!! |
Apr 18, 2007 - 3:54 PM |
1st might? looks like it. 2nd gen manifolds do.
This post has been edited by x_itchy_b_x: Apr 18, 2007 - 3:55 PM -------------------- |
Apr 18, 2007 - 4:41 PM |
Actually the 1st gen one is the same as the 5S but both versions of 2nd gen will fit [9 bolt requires some grinding]. If you look it appears that all of them will fit but some of the bolts can't be used and you will probably have to grind down the extra bolt hole areas at either end of the manifold. Not sure but that's what it looks like. I think only the 2nd gen one is a direct bolt up.
Apr 18, 2007 - 5:27 PM |
Be aware that the 1st gen manifold is a single entry type.
You won't be able to use twin-entry CT26 on it. However, a Supra CT26 or ST165 CT26 will bolt on. These turbos have different downpipe bolt pattern from twin entry CT26 and CT20B. You cannot use the downpipe that is made for twin-entry CT26 and CT20B. Also, IIRC, 1st gen manifold will place the turbo in a little different location. You might need to adjust the DP accordingly. This post has been edited by Gary: Apr 18, 2007 - 5:28 PM -------------------- _Gary
Apr 18, 2007 - 6:05 PM |
Thanks for the info guys, I always thought that the st165 manifolds won't fit at all or something.
Apr 19, 2007 - 10:19 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
2nd gen 7-bolt bolts up. I think the 9-bolt will go on too, I don't think there is anything in the way that would require the grinding of the extra two bolt holes, so you'll just have two holes that do nothing.
from the looks, 1st gen manifold might bolt up to a 5s too.. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Lo-Fi Version | Time is now: December 1st, 2024 - 9:40 PM |
