> Transmission oil question..., which one would you recommend?
post Apr 19, 2007 - 3:00 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I need to change tranny oil and I have had just one recommendation so far:
SHELL SPIRAX GSX 75W/80 (80W) GL-4
What do you think about that? What tranny oil you have been using? And also anyone here know what that "GL-4" grade means? (I have seen oils with GL-3 or GL-5 grade). Thanks for opinion...
oh.. and I forgot: how much I will need? 2litres?
This post has been edited by malpaso: Apr 19, 2007 - 3:01 AM
post Apr 19, 2007 - 11:50 AM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
I would recommend pennzoil/quakerstate synchromesh, if you can get it over there. That stuff is awesome! Search for a "chaning tranny fluid in a 7afe" or something like that thread, and it has a walkthrough of what to do, and more recommendations for synchromesh.
2 litres should do you good.
here you go: was in stickies
http://www.6gc.net/forums/index.php?showtopic=28245
This post has been edited by 6gsillyca: Apr 19, 2007 - 11:50 AM
post Apr 19, 2007 - 4:55 PM
mikew04
Joined Feb 19, '04
From austin tx
I use synchromesh as well and my 185k tranny still shifts smooth.
post Apr 20, 2007 - 1:04 AM
malpaso
Joined Feb 3, '06
thanks for answer... I know about that stickie wink.gif. But my problem is not "how" but "what" kindasad.gif. It's because I just don't understand those codes "75W/80 (80W) GL-4". Why not GL-3 or GL-5??? Why not 80W/90??? What is that 80W??? Are those numbers good? That's my aim...
note: that "pennzoil/quakerstate synchromesh" I can not find here frown.gif I don't eve know what is brand and what what is name of that oil biggrin.gif.
post Apr 20, 2007 - 3:09 PM
mikew04
Joined Feb 19, '04
From austin tx
http://www.pennzoil.com/products/gear_oil/syncro_fluid.html
80 is the viscosity, or how resistant to flow the oil is. like the 10 weight in your motor oil is more runny than an 80 weight in your tranny. the w stands for winter which means you can use it year round. the gl3 and gl5 i believe are service ratings for heavier equipment, so you shouldn't have to worry about that
I dont think they offer syncromesh in other viscosities, although I could be wrong.
post Apr 26, 2007 - 8:58 PM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
will this process work for an automatic tranny as well?? and how much is that bottle?
post Apr 26, 2007 - 9:20 PM
alltracman78
Joined Aug 9, '06
From Ma
No, for your trans you want ATF Dextron III.
QUOTE(mikew04 @ Apr 20, 2007 - 3:09 PM) [snapback]548886[/snapback]
Close.
80W-90 GL5
80 is how viscous it will be at 0*F. In this case, it will be as viscous as a 80 wt oil at 0*F.
W stands for winter grade, and goes with the 80 to signify it's viscosity is measured at 0*F.
90 is how viscous the oil will be at 212*F, it will be the same as 90 wt oil at 212*F.
GL5 is basically the shear strength of the oil [how well it resists being broken down under pressure].
As far as I know, only GL4 and 5 are used right now as a spec for gear oil.
GL5 is a little tougher, but is also more corrosive to yellow metals, such as bronze and copper.
Your synchros are made up of alloys of these.
Lo-Fi Version Time is now: November 30th, 2024 - 10:55 PM
