> Start up Squeel, sounds like a supercharger
post Apr 19, 2007 - 2:02 PM
Valo666
Joined May 15, '05
From Toronto
So for the last little while when i start up my car while its been sitting, it starts up squeeling like mad. like really whining. It lasts about 5 minutes or untill the engine warms up a bit. Its kinda weird. It seriously sounds like a roots style supercharger. I talked 2 some of my teachers and they said that its probably an ideler pulley. Any one else had this problem? Ill see if i can take a vide of it later tonight to show the sound. This only happens when the car has been sitting for like more than 3 hours.
post Apr 19, 2007 - 2:04 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
worn or loose belt(s)
it'll only get worse and start making the noise virtually all the time. check the tension in the belts and check for cracks/wear
I <3 Dustin---07/16/06
post Apr 19, 2007 - 2:19 PM
Valo666
Joined May 15, '05
From Toronto
its not my belts though..its coming from my timing belt. Like its a more metalic kind of sound. And also when i had my engine replaced, they replaced all the belts. The sound started when i got my new motor installed, so im thinkin it might have been a siezed bearing. But i am gonna b replacing my belts soon too just cuz they are starting to get a little worn and its only like $30 for them.
post Apr 19, 2007 - 3:28 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
check out the timing belt tensioner.
post Apr 19, 2007 - 3:36 PM
Valo666
Joined May 15, '05
From Toronto
thats what i figured...i went to the local car quest and they were sellin the ideler pulley and tensioner as 1 set.
post Apr 20, 2007 - 12:00 AM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
maybe the spring is just loose ? or the bearings in the pulley ? might as well just change out both the tensioner and pulley but in that case you might as well do the timing belt too.
Lo-Fi Version Time is now: December 4th, 2024 - 7:39 PM
