Ebay Gasget set |
Ebay Gasget set |
Apr 20, 2007 - 11:32 PM |
I was looking on ebay today to see if i could find a gasket set for the 5s.. I just wanted to know if anyone on here has bought a set off of ebay? and if so how is that working for you ...
here is a link to one of the sets i found Gasket Set 5S-FE Open to all Opinions -------------------- |
Apr 21, 2007 - 8:43 AM |
QUOTE(macavely @ Apr 21, 2007 - 12:32 AM) [snapback]549002[/snapback] I was looking on ebay today to see if i could find a gasket set for the 5s.. I just wanted to know if anyone on here has bought a set off of ebay? and if so how is that working for you ... here is a link to one of the sets i found Gasket Set 5S-FE Open to all Opinions mac, bill strong, the owner of mr2oc, just installed one of those ebay kits..although his was a even cheaper version...seems like the one you linked too at least has viton seals for the valve seals.. for 45$, not too bad. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 21, 2007 - 9:45 AM |
i like that one cause it has the metal head gasket.. i was looking at another that had a graphite seal... i have to do my home work on graphite seals ..
Apr 21, 2007 - 9:47 AM |
QUOTE(macavely @ Apr 21, 2007 - 10:45 AM) [snapback]549054[/snapback] i like that one cause it has the metal head gasket.. i was looking at another that had a graphite seal... i have to do my home work on graphite seals .. yea, any of the 98+ sets "should" have the MHG. good luck with the refresh! -------------------- Former Team 5SFTE pro member ;)
Apr 21, 2007 - 10:05 AM |
thanks.. .i just hope when i pull the motor and check everythong out .. i won't have to end up doing a full rebuild... but if thats the case might as well just go balls to the wall with the engine..
Lo-Fi Version | Time is now: December 2nd, 2024 - 8:57 AM |
