> Blowing Smoke Help!!, 94 st no oil leaks just burning oil??
post Apr 21, 2007 - 7:41 PM
SUPERPAC
Joined Sep 3, '05
From SAN DIEGO
Just bought a 94 st and it smokes and seems to be low on oil but is not leaking from underneath what is the next step 4 me 2 do???
post Apr 21, 2007 - 7:50 PM
Culpable04
Joined Apr 17, '06
From New Jersey
head gasket ??
post Apr 21, 2007 - 7:55 PM
95st-celica
Joined Mar 29, '07
From Philly
could be your o-rings...how bad is it? if i were you i would try seafoaming it (you wanna see some smoke??...hhaha its good smoke though it means its cleaning it out thumbsup.gif ) then changing your oil and getting some fresh in there..might help..if it's your rings its not worth pulling your whole engine apart to just put new ones in...it wont really hurt the engine it's just annoying to see smoke commin out all the time...i know the feeling i have the same problem with my 87 camaro.
1988 Dodge Aries K (sold)
post Apr 22, 2007 - 9:01 AM
SUPERPAC
Joined Sep 3, '05
From SAN DIEGO
QUOTE(95st-celica @ Apr 21, 2007 - 7:55 PM) [snapback]549153[/snapback]
I forgot to add the smoke is not blue,so the seafoaming is the same as an engine flush?
post Apr 22, 2007 - 9:06 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
well...what color is the smoke!?
post Apr 22, 2007 - 10:39 AM
SUPERPAC
Joined Sep 3, '05
From SAN DIEGO
QUOTE(Bitter @ Apr 22, 2007 - 9:06 AM) [snapback]549270[/snapback]
WHITE..NO BLUE IN IT...
post Apr 22, 2007 - 10:08 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Blue smoke = burning oil.
White smoke = burning coolant.
Get a pressure test done on your cooling system. More than likely you have a head gasket leak. Also have it tested both cold and hot. Because if it only leaks a little cold and a lot hot then you head is warping.
post Apr 22, 2007 - 10:12 PM
95st-celica
Joined Mar 29, '07
From Philly
yea its like an engine flush...like isaid give it a try..and while your add it replace your sparkplugs and add some fresh oil...even if it doesnt help you'll have already done that and have new everything for when you get a new headgasket
post Apr 23, 2007 - 7:09 AM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(bindertch @ Apr 22, 2007 - 10:08 PM) [snapback]549452[/snapback]
mm
Blue - oil burning
white - coolant burning or oil burning on the exhaust side.
This is mainly for the swapped folks that might come across a turbo leaking out the exhaust seals.
It also causes white smoke.
You most likely have a HG leak from what you are saying.
Lo-Fi Version Time is now: December 4th, 2024 - 6:44 PM
