Twin-charged 4AGZE (40+ pics!), Supercharged and Turbocharged |
Apr 22, 2007 - 9:47 PM |
nice
but, isn't that blue rubber oil return line a bit too close to that DP ? IMO that looks like a big problem waiting to happen...hope he doesn't go over too many bumps. -------------------- |
Apr 22, 2007 - 10:03 PM |
Enthusiast Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
Awesome work Doc and AngryMike
-------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Apr 22, 2007 - 10:09 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(Batman722 @ Apr 23, 2007 - 2:47 AM) [snapback]549441[/snapback] nice but, isn't that blue rubber oil return line a bit too close to that DP ? IMO that looks like a big problem waiting to happen...hope he doesn't go over too many bumps. No not at all, it's a few inches away... and there is zero play in the line, it's a monster hydralic line that's good to like, 600psi and 1000 degrees or something crazy like that... -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Apr 22, 2007 - 10:21 PM |
Enthusiast Joined Mar 19, '07 From savannah Currently Offline Reputation: 0 (0%) |
this was all tweaks mad science. i did a little aluminum welding and thats it.
the car turned out pretty sweet. as far as hydrolocking goes, you would have to fill all of the intercooler pipes, turbo, intercooler, supercharger and intake manifold before there would be a problem. i seriously hope somone would shut the car down if they were in water that deep. i hydrolocked my first car when i was 16. only flash flood in madison wisconsin for 20 years at least. figures. i can't wait to see the numbers myself. should be pretty fun. |
Apr 25, 2007 - 1:42 AM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
So you're using supercharged to push the turbo?
Apr 25, 2007 - 2:53 AM |
QUOTE(normality78 @ Apr 24, 2007 - 11:42 PM) [snapback]550435[/snapback] So you're using supercharged to push the turbo? ummm that is generally not how superchargers work.. I think the reason for dual charging the motor is to be able to run a larger turbo without the penalty of a large turbo lag. Because the supercharger will be creating power/boost while the turbo spools up. |
Jun 18, 2009 - 9:22 AM |
Enthusiast Joined Oct 19, '05 From Alabama Currently Offline Reputation: 0 (0%) |
I know this is a very, very old topic. I haven't been on here since I totaled my '94 celica in July of '07, i miss that car. I know some guys who would like to twin-charge their cars.
My question is Dr. Tweak do you have a diagram of how you set this system up? or could you explain how you ran the piping? how well did it work? I've always admired you work. One of the best I have ever seen. If you could help I would greatly appreciate it. Thanks, Nick |
Jun 19, 2009 - 11:01 AM |
Enthusiast Joined Jan 28, '07 From Québec, Canada Currently Offline Reputation: 1 (100%) |
the real big thing would be a dual intercooler, twin charged engine. It would be that way :
air filter --- turbo --- intecooler 1 --- supercharger --- intercooler 2 --- intake manifold I know some 2 stage industrial compressor are doing it, why not try it into an engine! Would be very nice! Any way, how did this history end? Sam |
Jun 19, 2009 - 11:59 AM |
the real big thing would be a dual intercooler, twin charged engine. It would be that way : air filter --- turbo --- intecooler 1 --- supercharger --- intercooler 2 --- intake manifold I know some 2 stage industrial compressor are doing it, why not try it into an engine! Would be very nice! Any way, how did this history end? Sam to have a good icooling effect at least one of the intercooler have to be water to air, since there won't be enough room for 2 decent size intercoolers on the front of the car and also cool the coolant at the same time. but this is good idea, I'm sure a good plumber can figure this out quick. the good question here is if they have come up with a reliable way of disengaging the mangetic cluthc on the supercharger ( does it have one ? ) so it doesn't take power away from the engine when the turbo is pushing. I now HKS had something like this back in the day but never worked as expect it. -------------------- |
Jun 20, 2009 - 3:56 AM |
the old 80's supercharged mr2 cars had the 4a-gze with this supercharger clutch, i think also the gt-z levin & trueno also had it since a friend of mine that had a gt-z complained about the blower disengaging or some ****.
i really want to see comparisons of 3 dyno sheets (not just max power but the torque curve i want to check) with the standard 4a-gze, then the 4a-gze with front mount and finally the 4a-gtze/4a-gzte -------------------- Mike W
Jun 20, 2009 - 8:31 PM |
Enthusiast Joined Jan 17, '04 From Boston, MA Currently Offline Reputation: 1 (100%) |
Incredible work.
I had to scratch my head a few minutes to follow the piping. Look forward to some numbers, if the owner eve wants to post them. Regards; -------------------------- |
Jun 22, 2009 - 10:21 AM |
I know this is a very, very old topic. I haven't been on here since I totaled my '94 celica in July of '07, i miss that car. I know some guys who would like to twin-charge their cars. My question is Dr. Tweak do you have a diagram of how you set this system up? or could you explain how you ran the piping? how well did it work? I've always admired you work. One of the best I have ever seen. If you could help I would greatly appreciate it. Thanks, Nick Hi Nick, and thanks to all of you for the kind comments. Honestly I wasn't real happy with the end result of this system. A lot of it had to do with the fact that I did it for a few hundred bucks for a friend with a VERY limited budget. The end result was that not enough time or money was spent in some important places (fuel management specifically) and that caused some problems (he blew the engine). He replaced the long block and ran it again with no other changes and unfortunately that engine starting having problems as well. I had him bring the car back to me for some diagnosis and to change the fuel management to an AEM F/IC and do some better tuning. After a compression test I found that one of the cylinders was bad so we stopped there. He ended up bringing the car to another friend to have the whole system redone and the engine rebuilt. He felt that the system that I built on the engine was faulty and that I owed him a new engine. Long story short I bought a new engine for him. Unfortunately there's a lot of resentment on both sides and the whole ordeal all but put an end to the friendship. The moral of the story is: 1. When it comes to your job, don't do favors for friends. You don't get paid for your work, your friend doesn't get the service he deserves, and the friendship may be damaged irreparably. 2. When it comes to doing unusual, out-of-the box builds, make sure you have enough money, don't cut corners, and be prepared for setbacks. As far as the subject of twin-charging, I think that it could still be done effectively but some things need to be changed to make better use of both the supercharger and the turbo. Also I would have used a larger turbo and found a way of combining the charged pipes instead of feeding one to the other. The bottom line is that the expense probably is higher than the benefit that you get and money would be better spent on a straight turbo build, unless you really want to do something unusual. -Doc This post has been edited by Dr_Tweak: Jun 22, 2009 - 10:23 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jun 22, 2009 - 10:29 AM |
Enthusiast Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
that sucks Tweak. U do good work ur friend started out cheap so he got what he paid for.
Jun 22, 2009 - 10:55 AM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Your friend must not be too bright, adding a power adder to an already FI'd motor without proper tuning capabilities? What did he expect the outcome would be?
Jun 22, 2009 - 11:09 AM |
That's a real shame that it ruined your friendship. It's too bad more people aren't able to distinguish the difference between business and friendship. If he'd been a *true* friend, he would've respected you enough to pay you for your services. You're not in the business for the feel-good of it, ultimately, you have to make a living. He took advantage of you. And in the process, it sounds like it cost him a hell of a lot more money anyway than he would've spent had he just shown more respect and been mature enough to separate business from friendship.
Rest assured that one day when I show up on your doorstep with a 6th gen, I'll be able to separate the two! That said, so who's gonna be first on here to show up at Doc's doorstep with twin chargers gleaming in their eyes!? Sounds like a really fun and challenging project! -------------------- |
Jun 22, 2009 - 12:41 PM |
Thanks Doc.
Sorry to hear about all that happened. That guy was not a "True" Friend at all. I wish everything would have all turned out ok. I'm really sorry, man. I wish I had a 6th gen again, I wanted mine converted into a GT-4 so bad. I went to a show this weekend and a guy had a RX-7 converted to a JDM RX-7, I almost cried thinkin "I wish I could have converted my 6th gen Celica." |
Jun 23, 2009 - 11:19 AM |
Thanks guys
Jun 23, 2009 - 11:38 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
His loss, i'd let you build my engine anyday!
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Lo-Fi Version | Time is now: November 30th, 2024 - 4:26 PM |
