> Throttle barrel kit?
post Apr 22, 2007 - 7:39 AM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
Hi,
I need to make a custom throttle cable by cutting the lead barrel (nipple) off a standard throttle cable, shortening it and then fixing a new barrel. I've seen barrels with a clamping screw or nut being advertised but don't like the idea.
Is there a DIY kit available to cast a new lead barrel or solder a brass barrel to the throttle cable? Alternatively, is it something that some garages are geared up for doing?
post Apr 22, 2007 - 8:40 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
find (if you can) a lead fishing weight mold and use that to cast the cable ends from aluminum...because thats not lead.
Lo-Fi Version Time is now: December 2nd, 2024 - 2:19 AM
