> FRONT WHEEL BEARINGS
post Apr 22, 2007 - 10:07 PM
n2toyotas
Joined Apr 22, '07
From Birmingham, Al
I just bought my daughter a 97 Celica ST Limited Edition. Im trying to pin point a noise that I get when going above 40 mph but very prominent at 70. I get a thumping type noise that sound like a tire that was rotated and cupped but the tires (though needing to be replaced due to not much tread left) seem to be evenly worn. Could this be a wheel bearing. Im more use to a bearing making a roaring type noise.
post Apr 22, 2007 - 11:26 PM
you could always jack it up and place ur hands at 9 and 3, then push in and out if you can its highly likely you have a bearing problem
you can get them + seals from advanced auto fairly cheap and have a local mechanic install them as well
post Apr 23, 2007 - 12:26 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
my front bearing is bad too i believe, makes a squeeling noise when accelerating.
post Apr 23, 2007 - 12:39 PM
Drew-887
Joined Jan 5, '05
From Upper Darby, PA(5 min away from Philly)
Im having the same problem. My Front wheel on the drivers side Squeeks really bad when I drive. Does that sound like a wheel bearing problem?
post Apr 23, 2007 - 12:54 PM
LewFX
Joined Jan 28, '05
i reckon so, but ill find out
post Apr 23, 2007 - 9:48 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(n2toyotas @ Apr 22, 2007 - 10:07 PM) [snapback]549450[/snapback]
What part of "The Ham" are you from?
From my experience a wheel bearing is usually a roaring noise.
Squeaks are normally something with the brakes.
As for you, try rotating the tires front to back and see if it changes at all.
If it does, it's your tires.
If not, check your suspension parts, wouldn't hurt to have the alignment checked too, though it most likely isn't going to cause noise.
Lo-Fi Version Time is now: November 27th, 2024 - 1:26 PM
