> DCW single pod
post Apr 23, 2007 - 11:43 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
What have you used to keep it in place ? I have double sided tape holding it. Upon acceleration it tends to fly off the dashboard laugh.gif
I will return one day.
post Apr 23, 2007 - 12:12 PM
snapshotgt
Joined Oct 12, '05
From Texas
Don't know if you've seen this (not sure if it helps..):
QUOTE(doGGy @ Nov 1, 2006 - 6:13 PM) [snapback]498441[/snapback]
Firts ofcorse - run all the wiring through the center piece of dash (on the top of the center piece). Make sure they are accesible once you going to put the pod on the dash. Dont fix the plastic (center piece) fully, leave it in the place but make sure there is a gap on top (between the center plastic and dash, in this gap wires should go)
After this - put all the gauges in the pod, fix them.
Then you gonna install it - Use Double side tape to fix it on the dash. Make sure to clean the dash with some sort of Anti-fat alcohol or somthing. Then do the same with the pod underside. Put the double side tape on the pod inner side near the edge as much as posible everythere there the pod touches the dash. Then i would suggest to use a hairdryer to heat up whole pod a bit (DO NOT USE normal heat gun cuz you might damage the pod by overheating it) Hairdryer will do just fine - heat up the pod it will get a little bit softer so it will be easyer to fix it on the dash + it will get the shape of the dash while its soft smile.gif
Post all the pics after install and while you will be installing it smile.gif
post Apr 23, 2007 - 12:19 PM
get the double sided tape thats rated for 5lb. its red/gray instead of green/white. that should hold it.
post Apr 23, 2007 - 5:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Thanks guys. I'll try this stronger tape you speak of.
post Apr 28, 2007 - 11:24 AM
doGGy
Joined Oct 28, '02
From Europe, Lithuania
I used silicone based Glass glue on every car i'v installed it - never seen them fall away biggrin.gif maybe you have way too much Tq Jeff... biggrin.gif
<<<<<< DCw / JDMart >>>>>>>
Lo-Fi Version Time is now: January 8th, 2025 - 8:49 AM
