12 Pages V  « < 7 8 9 10 11 > »
> added a CAI today
post Jul 25, 2007 - 1:20 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Because people either can't use the search button or they don't read the previous pages to get all the info they need and proceed to post at the end because it takes less effort.
9 pages now.
This post has been edited by Sinyk: Jul 25, 2007 - 1:21 PM
post Jul 25, 2007 - 1:22 PM
Redline08
Joined Feb 23, '07
From Albany, NY
haha, this was the only post i found with eautosource in it, thats why i posted cause i needed info about them
who cares if its nine pages? lol
post Jul 25, 2007 - 6:48 PM
Jlacker3
Joined Jul 3, '07
From Texas
On the GT some people cut the S pipe...and some cut the L pipe to make the intake fit properly in the Celica. I was wondering @ what measurements (how many inches down from one end to the other did you make the cut on each pipe or IF both)
Thanks!
I sure hope its not a 3 in. pipe, cause I need to do something quick, my stock intake has a huge crack in it.
post Jul 25, 2007 - 7:02 PM
Redline08
Joined Feb 23, '07
From Albany, NY
even if it is a 3" pipe u can just widen the hole and move the fuse box, prolly will take about an hour more, depending on your skill.
post Jul 25, 2007 - 8:11 PM
dutchboy
Joined Jun 28, '07
QUOTE(Sinyk @ Jul 23, 2007 - 12:38 PM) [snapback]581509[/snapback]
I think I actually shifted it towards the engine after pulling it off this past weekend, but it doesn't cause problems. I don't expect it to move much and it's not pushing against the reservoir.
Mine took 10 days to arrive.
My thinking about being close to the brake fluid reservoir is if you hit/get hit on the front left, the pipes could cause damage to the reservoir or master cylinder, making repairs more costly and time consuming...
post Jul 26, 2007 - 11:44 AM
Sinyk
Joined Oct 4, '06
True, but if I get hit, then my insurance is going to cover it as well as the rest of my car that got crunched in the accident. I checked and it is farther from it since I took it off and put it back on, so problem solved. I had a lot of extra pipe on the L-shaped piece so I was able to shift the S-shaped piece farther away.
post Jul 26, 2007 - 1:08 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
QUOTE(Redline08 @ Jul 26, 2007 - 12:02 AM) [snapback]582374[/snapback]
widening the hole wont be an easy task. You have to do the widening using a grinder or air saw, then you have to get rubber siding to make sure the pipe is worn down by the edge of the metal. Your stock air tube is fitted perfectly, this is a round tube and obviously wont be perfect.
In response to the cutting, I believe I took about 3 inches off the end of the S pipe closer to the battery, and I took about 1 inch to 1.5 inches off the end that connects to the throttle body, I might even recommend cutting 2-2.5 because of fitting reasons. It runs against some fluid thing if you look at one of my pictures.
ALSO
eautosource, I would not recommend. They are obviously too overloaded for their employee count. They barely communicated, and didnt leave feedback. Infact it was so difficult to contact them, I decided to stay with the 3 inch pipe, after all, unless you are making a cold air intake (50 extra bucks for the bypass valve) then you can simply by a 2-3 inch coupler for the throttle body hole.
WHEW.
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Jul 26, 2007 - 1:56 PM
Redline08
Joined Feb 23, '07
From Albany, NY
in response to your rubbing try cutting the end of aluminum that connects to the throttle body, about an inch, that should stop the rubbing.
and making the hole bigger would be easy for me but i guess not for all, o well
post Jul 26, 2007 - 2:02 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
QUOTE(Redline08 @ Jul 26, 2007 - 6:56 PM) [snapback]582631[/snapback]
yeah i was plannin on that when i get the time, its not hard, just gotta pull it off and saw and clean tongue.gif probably a 30 min job.
My Celica's SRI
post Jul 26, 2007 - 2:22 PM
Sinyk
Joined Oct 4, '06
Ok, your guys' pipes must've been different than mine. I didn't have any extra I could cut off on the end connecting to the throttle body. I ended up taking probably 3 inches off of the end connecting to the filter though.
post Jul 26, 2007 - 2:28 PM
Redline08
Joined Feb 23, '07
From Albany, NY
sinyk you probably messed up the pipes? i dunno throw me a pic thanks lol
post Jul 26, 2007 - 3:19 PM
Sinyk
Joined Oct 4, '06
Go back through the thread... I have like 5-6 pics up... It's hard to mess up that pipe tongue.gif
post Aug 2, 2007 - 7:13 PM
Jlacker3
Joined Jul 3, '07
From Texas
I just got my CAI from eautosource delivered today. Its 2.75 in wide. Does anyone have a sound clip of CAI WITH the bypass valve?? I don't know if I'm gonna do CAI custom SRI with the kit.
post Aug 2, 2007 - 7:37 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
QUOTE(Jlacker3 @ Aug 3, 2007 - 12:13 AM) [snapback]584793[/snapback]
I believe 2.75 will work with the stock hole, though I am not sure. Ask around, also, If you have the money, I'd buy a bypass valve and do the CAI, you will get better HP than an un-heatshielded/airboxed SRI.
.02
My Celica's SRI
post Aug 2, 2007 - 9:20 PM
Redline08
Joined Feb 23, '07
From Albany, NY
bypass valve = louder = better lol
post Aug 2, 2007 - 10:06 PM
95st-celica
Joined Mar 29, '07
From Philly
QUOTE(Redline08 @ Aug 2, 2007 - 10:20 PM) [snapback]584819[/snapback]
possiably but the bypass valve means more restricted air flow and less performance which is what your lookin for...mine is loud as **** without it
1988 Dodge Aries K (sold)
post Aug 2, 2007 - 10:33 PM
Redline08
Joined Feb 23, '07
From Albany, NY
So put it on when its raining, its not like you even need it
post Aug 2, 2007 - 11:55 PM
95st-celica
Joined Mar 29, '07
From Philly
exactly....what im sayin is you dont need it period and it restrics performance....and without it, it is still very loud both inside and outside the car
post Aug 3, 2007 - 7:56 AM
Redline08
Joined Feb 23, '07
From Albany, NY
wait, you said in one post, bypass valve=less noise, and in another thread you said bypass valve=more noise
vs.
So is it louder or quieter with the bypass valve ON? lol im so confused
it must have been late when you wrote those, i always get screwed up when its late lol
post Aug 3, 2007 - 2:05 PM
95st-celica
Joined Mar 29, '07
From Philly
no i said the same thing in both posts...you must have just read them wrong....all im sayin is that its very loud without the bypass valve and if your only puttin it in for the noise factor its stupid because it cant be much louder.....the main reason i dont have one in besides the fact you really dont need one if you use the same cai i used is because it restrics air flow
Lo-Fi Version Time is now: December 2nd, 2024 - 1:31 PM
