trubo question, i need help |
Apr 23, 2007 - 8:45 PM |
Enthusiast Joined Mar 7, '07 From dallas texas Currently Offline Reputation: 0 (0%) |
i wan to boost my 5sfe and i have like 154000 miles on it, would it be worth my while to turbo it or is that too much miles?
-------------------- DRIVE UP..........
ACCEPT THE CHALLENGE......... DESTROY YOUR OPPONENT......... |
Apr 23, 2007 - 8:55 PM |
in most cases , its really depends more on the condition of the motor, more so the amount of miles.
typicly tho, 150K+ is not the best time to think about turboing a motor. i cant remember how many miles vins had when we turboed it. im sure he'll post once he sees this tho -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Apr 23, 2007 - 8:59 PM |
Enthusiast Joined Mar 19, '07 From savannah Currently Offline Reputation: 0 (0%) |
compression and leak down test will tell you if you should or not.
any local shop should be able to preform at least the compression test. |
Apr 23, 2007 - 9:26 PM |
Enthusiast Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
when i turbo mine it was close to 130k miles. but mine was in a pretty good condition and installed by J.D.M. guy after more than 10k miles it's still running strong. but yea like manny said.. with that many miles you should consider swapping. but if you really are determined to turbo it.. do wat angry mike said. and also change head gasket, check for annnnnny leaks etc.
Lo-Fi Version | Time is now: November 29th, 2024 - 6:49 AM |
