Enthusiast ![]() Joined Mar 4, '07 From bayville Currently Offline Reputation: 5 (100%) ![]() |
does the lock nut/bolt thing on the 94GT the same for the 94-99 ST and GT's? cause i lost mine and i dun wanna go to toyota dealer and spend alot to get a new one...so if anyone lives in byville, and knows the answer pm me cause ill need ya
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 28, '04 From Houston, Texas Currently Offline Reputation: 2 (100%) ![]() |
There are thousands of bolts on your car. Which one are you talking about?
sorry i was in a rush for work, its the one for the tire to get the tire off, i can get the other 4 off but the 1 bolt has the special cutout where you need the special bolt....im tryin to paint my calipers blue but i realized i couldnt find by bolt thing, so i had to halt the project
![]() Enthusiast ![]() ![]() ![]() Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) ![]() |
It's called wheel lock.
You will need a specific key to remove it. The key is similar to a socket with special pattern that matches the wheel lock. You slip it over the wheel lock, then turn it with a lug nut wrench. They are all different by the way. -------------------- _Gary
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
yeah. I had those on my car. while trying to remove a couple of them, I stripped a couple. what a pain to get off! if you just need them off, go out and buy 4 19mm 12-point deep sockets. not your nice sockets you already have, go out and buy cheap ones! what you'll need to do is, using a dremel or a hammer and chisel (a combination of the two works well) cut/chip a corner of the wheel lock off, now take one of the sockets and take a hammer and wack it onto the wheel lock until it's on there pretty far, it doesn't really want to go on unless you have a piece chipped off.. now you can take a ratchet, stick it in the socket, and it should be able to turn the lock off.
dremel blades - $5 cheap sockets - $28 ($7ish each) 4 new lug nuts from toyota - $25 (universal ones didn't fit for me) probably cheaper to just get a new key. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Man 6strings - talk about doing something the hard way LOL. Just take it to NTB or discount tire [or whatever your local chain tire store is] and they will remove them for around $8 each. Then get you some more with a key because if you have nice rims they are a must. If you don't and plan to get some - don't worry about it. Most rim shops will through them in as a deal sweetner if you know how to deal.
QUOTE(Negative @ Apr 26, 2007 - 6:31 AM) [snapback]550913[/snapback] Man 6strings - talk about doing something the hard way LOL. Just take it to NTB or discount tire [or whatever your local chain tire store is] and they will remove them for around $8 each. Then get you some more with a key because if you have nice rims they are a must. If you don't and plan to get some - don't worry about it. Most rim shops will through them in as a deal sweetner if you know how to deal. I called a bunch of tire places and they all said that they couldn't/wouldn't get them off. I plan on getting some locks again when I go to some better wheels. I just have to make sure that they always get torqued properly and not put on with an air impact so that they are so freakishly tight that I just strip the heads of them when I try to get them off. ![]() -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
![]() Enthusiast ![]() ![]() Joined Feb 28, '07 From Columbus, OH Currently Offline Reputation: 2 (100%) ![]() |
find a shady little tire/rim place near you and ask them. I have a guy on the east side that hooked me up. He also just gave me a set of 20 locks when I had him mount and balance the rims Jaws sold me.
20 locks? One for each lug? or did you mean 1 for each wheel and the rest were undersized lugnuts for aftermarket rims?
This post has been edited by Negative: Apr 26, 2007 - 2:47 PM -------------------- ![]() |
one for each lug. I'll put up pics.
Lo-Fi Version | Time is now: February 19th, 2025 - 5:09 PM |
