> passenger air vent
post Apr 26, 2007 - 5:07 PM
Jared95
Joined Apr 24, '07
From lufkin tx
how do u pop that thing out?
post Apr 27, 2007 - 11:05 AM
DSToyo
Joined Dec 16, '06
From Maryland
do a search....just pull or pry it off. there are 2 tabs that youll probably break but itll still go back in fine.
post Apr 27, 2007 - 11:17 AM
Negative
Joined Apr 28, '04
From Houston, Texas
Pull from the bottom up and the tabs won't break. It will take alot more force than seems reasonable but it is necessary.
post Apr 27, 2007 - 11:44 AM
DSToyo
Joined Dec 16, '06
From Maryland
i thought the tabs were on the bottom....therefore pull from the top? right---whatever you do, pry slowly
post Apr 27, 2007 - 2:49 PM
goferris
Joined Feb 14, '07
From Provo, UT USA
what i did was used a small flathead on the top. there are 2 metal clips that were a b**** to get out. the bottom tabs that are known to break are pretty much useless. some suggested pulling out the glove box but i don't think it is necessary at all.
if you still need help i will see if i can post some pics up later tonight
post Apr 27, 2007 - 3:54 PM
Negative
Joined Apr 28, '04
From Houston, Texas
QUOTE(DSToyo @ Apr 27, 2007 - 4:44 PM) [snapback]551496[/snapback]
Yeah - got that backwards. Was doing it from memory. LOL. Would have made him break them for sure.
post Apr 28, 2007 - 6:20 PM
Jared95
Joined Apr 24, '07
From lufkin tx
yeah thanks it worked....and u were right it snapped off the bottoms but it slid back in and fit no prob
Lo-Fi Version Time is now: January 9th, 2025 - 8:23 AM
