> HKS SSQ, Leaking ....Maybe pluged to the wrong vaccum line
post Apr 26, 2007 - 7:18 PM
Gmoney1
Joined Feb 9, '07
From St.lucia
pluged up my HKS SSQ today ..... so anxious to hear some noise ..... but then realized that @ 0 vaccum ... where boost begins to build ... it stays @ 0 vac. but then u hear it go through the BOV. Can anyone give me some advice as which line to use for the BOV , on a 2nd Gen 3SGTE.
post Apr 26, 2007 - 7:34 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Gmoney1 @ Apr 26, 2007 - 7:18 PM) [snapback]551204[/snapback]
Pics???? Use any vaccum hose that is under boost pressure after the throttle body.
post Apr 26, 2007 - 9:33 PM
tee into the line the goes to your map sensor. passengers side of the intake manifold.
post Apr 26, 2007 - 10:17 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Apr 26, 2007 - 9:33 PM) [snapback]551268[/snapback]
I thought that was a bad place to tee into. You want the shortest and most simple line to the map sensor so It doesnt throw the ecm off. right?
post Apr 26, 2007 - 10:41 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I wouldnt recommend the map sensor. The line in the picture below works very well. Just need to buy a reducer. The hose is a little bit bigger than the HKS supplied hose.
Sorry for the bad pic.
I will return one day.
post Apr 26, 2007 - 11:04 PM
whats wrong with using the map sensor line?
post Apr 26, 2007 - 11:14 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(lagos @ Apr 27, 2007 - 12:04 AM) [snapback]551305[/snapback]
with an AFM nothing. all that is for is for boost cut and the stock boost gauge we don't have.
oh and getting what altitude your at when u start up. but on a speed density system the map should be close with short lines so it has a more responsive route to make critical fuel calculations. the more accurate the sensor, the better. less space to fill before the map starts to read pressure. something like that. i really just remember it from mr2oc.
This post has been edited by x_itchy_b_x: Apr 26, 2007 - 11:15 PM
post Apr 26, 2007 - 11:18 PM
yeah thats what i mean. its pretty much used for fuel cut and thats about it.
mine is in that exact state at the moment...lol
post Apr 26, 2007 - 11:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
I'm more comfortable running off the intake manifold. That port on the side works very well for a vac source.
post Apr 26, 2007 - 11:22 PM
there is also a free port on the back of the manifold thats normally capped off. i think it a 6m or 8m hose connection. you can use that with a vac line reducer. i think thats where i have mine at the moment.
post Apr 27, 2007 - 5:23 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Apr 26, 2007 - 11:18 PM) [snapback]551311[/snapback]
Correct me if Im wrong, but say....you tee into the boost pressure sensor line and one of the hoses blow off. Wouldnt the fuel cut be eliminated. Thus unlimited boost. I know its rare circumstances. But I just dont want to take any chances. Plus it always seems that toyota does things for a reason and I dont realize why until its too late. (like not teeing anything into this line) Learning the hard way. biggrin.gif Maybe Im just paranoid.
post Apr 27, 2007 - 6:45 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
the tvsv is what limits the boost, not the fuel cut/map sensor. if somehow ur car is overboosting and then the line is blown off, then maybe there will be a problem.
bboy
post Apr 27, 2007 - 11:14 AM
QUOTE(toyotacrazy @ Apr 27, 2007 - 6:23 AM) [snapback]551385[/snapback]
no. not at all. your waste gate and boost controller are what controls your boost. the map sensor (on the 2nd gen) is just there as a backup to cut fuel. if you disconnect it, your boost level wont change. in fact a lot of people disconnect the map sensor vac line or install an fcd to run more then the 12psi allowed by the map. using a tee on that line wont do any harm.
post Apr 28, 2007 - 12:07 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Apr 27, 2007 - 11:14 AM) [snapback]551477[/snapback]
Ive seen 14 psi on my celica then hit fuel cut. Since mine is a JDM ecm is this normal? Or is my boost gauge inaccurate?
post Apr 28, 2007 - 12:42 AM
BBoYRuGGeD
Joined Jun 4, '04
ur probably running later year 2 board ecus. i think they had higher fuel cut. i know i was disappointed when i found out my cut was at 12 kindasad.gif since the engine importer gave me the wrong year ecu (engines a 93, ecus a 90-91 single board)
bboy
post Apr 28, 2007 - 11:09 AM
QUOTE(BBoYRuGGeD @ Apr 28, 2007 - 1:42 AM) [snapback]551776[/snapback]
bboy
its very simple to change or eliminate fuel cut if you want to run more boost.
toyotacrazy, i would blame the boost gauge.
This post has been edited by lagos: Apr 28, 2007 - 11:11 AM
post Apr 28, 2007 - 11:35 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(lagos @ Apr 28, 2007 - 11:09 AM) [snapback]551856[/snapback]
bboy
Yea. Im keeping my eyes open for an electronic one
post Apr 30, 2007 - 12:30 PM
eggman40
Joined Aug 17, '04
From California
QUOTE(defgeph @ Apr 26, 2007 - 8:41 PM) [snapback]551299[/snapback]
Thats exactly how and where i ran my vac line. My ssqv came with the reducer though.
post Apr 30, 2007 - 12:45 PM
BBoYRuGGeD
Joined Jun 4, '04
yah thats the spot i got my hks ssqv and my boost gauge connected to also. do u guys also T ur boost gauge and BOV together or do u run 'em on seperate lines? im thinking of moving my bov line to the back of the manifold since it doesnt seem responsive enough T'd of with the boost gauge.
-bboy
post Apr 30, 2007 - 12:55 PM
I have my boost gauge off the manifold.
Lo-Fi Version Time is now: December 11th, 2024 - 6:03 PM
