anyone swap 7afe to 4age/4agze before? |
Apr 27, 2007 - 1:07 PM |
Enthusiast Joined Mar 15, '05 From Gurnee,Illinois Currently Offline Reputation: 0 (0%) |
Well i found a 95 Celica ST ST200 with 7AFE Engine in it, i probably getting that car as well since it's Manual Transmission. so that makes it 2 Celicas i'll be owning. Giving my brother my Automatic Celica GT 5SFE.
I just want to know if anyone swap a 7AFE to 4AGE or 4AGZE(even though i know it's more recommended for street driving with good end torque) engine before and the results of it success? I know i read the Feasible and Non-Feasible Engine Swaps Topic said, "Celica with a 7A-FE(USDM ST) because both engines are A-series engines. This engine will bolt right up to your stock USDM ST(AT200) transmission." someone care to explain what that means in the parenthesis? does it mean it's easier to swap because the motor mount can hold the 4AGE/4AGZE as well or is it something else behind that meaning? I'm planning to do engine swapping in my dad's shop if it doesnt require any welding or special setup to put the 4AGZE in the ST Celica. Much info or help is much appriciate from the ones that have good knowledge and experience |
Apr 27, 2007 - 1:17 PM |
QUOTE(syaoran60085 @ Apr 27, 2007 - 1:07 PM) [snapback]551521[/snapback] Well i found a 95 Celica ST ST200 with 7AFE Engine in it, i probably getting that car as well since it's Manual Transmission. so that makes it 2 Celicas i'll be owning. Giving my brother my Automatic Celica GT 5SFE. I just want to know if anyone swap a 7AFE to 4AGE or 4AGZE(even though i know it's more recommended for street driving with good end torque) engine before and the results of it success? I know i read the Feasible and Non-Feasible Engine Swaps Topic said, "Celica with a 7A-FE(USDM ST) because both engines are A-series engines. This engine will bolt right up to your stock USDM ST(AT200) transmission." someone care to explain what that means in the parenthesis? does it mean it's easier to swap because the motor mount can hold the 4AGE/4AGZE as well or is it something else behind that meaning? I'm planning to do engine swapping in my dad's shop if it doesnt require any welding or special setup to put the 4AGZE in the ST Celica. Much info or help is much appriciate from the ones that have good knowledge and experience there is no such thing as a 1995 celica ST200, the celicas STs as far as I know are chasis code AT200 do a search and you'll see members with those swaps done and their experiences. it doesn't mean easier swap, it means that you won't need new motor mounts or new tranny so is somewhat a little less work involve but I wouldn't say easier. unless you're putting the same engine as stock ( swaping a 7AFE for another 7AFE with the same specs ) any swap require special set-up. This post has been edited by Culpable04: Apr 27, 2007 - 1:18 PM -------------------- |
Apr 27, 2007 - 1:21 PM |
My typo mistake error on the ST200, i meant AT200
Apr 27, 2007 - 1:29 PM |
QUOTE it doesn't mean easier swap, it means that you won't need new motor mounts or new tranny so is somewhat a little less work involve but I wouldn't say easier. Easier swap in what terms? Yes it is an easier swap than an S-series engine (3SGE, 3SGTE, etc.) because you can use your current motor mounts and you can use your current transmission. You would need the 4AGE, ECU, harness, etc. You will want to replace the gaskets, timing belt, water pump, etc. while it is out - plus add some fun stuff like cams and cam gears - because you can't leave an engine alone for too long. This post has been edited by 95CelicaST: Apr 27, 2007 - 1:29 PM -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 27, 2007 - 1:33 PM |
QUOTE(95CelicaST @ Apr 27, 2007 - 1:29 PM) [snapback]551536[/snapback] QUOTE it doesn't mean easier swap, it means that you won't need new motor mounts or new tranny so is somewhat a little less work involve but I wouldn't say easier. Easier swap in what terms? Yes it is an easier swap than an S-series engine (3SGE, 3SGTE, etc.) because you can use your current motor mounts and you can use your current transmission. You would need the 4AGE, ECU, harness, etc. You will want to replace the gaskets, timing belt, water pump, etc. while it is out - plus add some fun stuff like cams and cam gears - because you can't leave an engine alone for too long. Thanks alot for the info! Makes me feel better to hear that! though, i do have to replace the tranny too right? since the 7AFE tranny cant handle too much power boost from the 4AGZE? |
Apr 27, 2007 - 1:39 PM |
yeah, if you get the AE101 4AGZE you can use the tranny that comes with it - it will hold the boost a bit better... but for some reason I think it is a C52 trans as well... maybe someone can shed some light on that?
Apr 27, 2007 - 1:44 PM |
QUOTE(syaoran60085 @ Apr 27, 2007 - 1:33 PM) [snapback]551538[/snapback] QUOTE(95CelicaST @ Apr 27, 2007 - 1:29 PM) [snapback]551536[/snapback] QUOTE it doesn't mean easier swap, it means that you won't need new motor mounts or new tranny so is somewhat a little less work involve but I wouldn't say easier. Easier swap in what terms? Yes it is an easier swap than an S-series engine (3SGE, 3SGTE, etc.) because you can use your current motor mounts and you can use your current transmission. You would need the 4AGE, ECU, harness, etc. You will want to replace the gaskets, timing belt, water pump, etc. while it is out - plus add some fun stuff like cams and cam gears - because you can't leave an engine alone for too long. Thanks alot for the info! Makes me feel better to hear that! though, i do have to replace the tranny too right? since the 7AFE tranny cant handle too much power boost from the 4AGZE? that's true but easier is based on whatever amount of experience you have, you have members here that can have an swap up and running in one month with no rushing, and I bet you that the same swap done properly will take me 1/2 of a year probably lol. you can do it I'm sure you can, just take your time and get all the info together, do a lot of search and you'll see what problems you may run into and how to deal with them, try to learn from others experiences. QUOTE(95CelicaST @ Apr 27, 2007 - 1:39 PM) [snapback]551543[/snapback] yeah, if you get the AE101 4AGZE you can use the tranny that comes with it - it will hold the boost a bit better... but for some reason I think it is a C52 trans as well... maybe someone can shed some light on that? the tranny will hold the power just fine Nik had / have ( don't know if the car is sold ) his ST with a 7AGTE and he used the stock tranny along with a LSD, he was pushing over 300 HP at the wheels. -------------------- |
Apr 27, 2007 - 1:49 PM |
I think the GZE trans comes with LSD though, so you wouldn't need to buy an aftermarket one.
I think Nik had his rebuilt though when the LSD went in.. wouldn't make sence to open it up to only put in an LSD -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Apr 27, 2007 - 2:07 PM |
Thank you both for the info. i will stick with 7AFE for now and have fun driving stick shift plus the gas saving on this engine. that way i can save up the money whatever require for me to do the swapping and tuning parts for 4AGZE in the future then put it under the Celica ST's hood
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:20 PM |
