![]() Enthusiast ![]() ![]() ![]() Joined Nov 22, '05 From Mesquite, Texas Currently Offline Reputation: 0 (50%) ![]() |
Hey guys today one of the worst days that my celica has ever seen. I was coming back from getting my check in dallas when i heard a strange rubbing (like the belts were tangled) and then CA-POW!
Not sure how the whole process happened the only think i can think is when the timing and water pump went it caused oil pressure to surge and pop the oil return line off which caused all the oil to drain on the concrete. This is really going to set back my turbo set up. ![]() Anyhow car is getting fixed be ready tomorrow but here are some pics for your viewing. ![]() ![]() ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 6, '06 From massachusetts Currently Offline Reputation: 30 (97%) ![]() |
That same thing happened to me man. It sucks but in the long run it will make your car run a LOT better. But for now it sucks.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
when was the last time you change your water pump.
I'm 90% sure your water pump failed causing your timing belt to go with it. |
QUOTE(Hanyo @ Apr 27, 2007 - 8:31 PM) [snapback]551686[/snapback] I'm 90% sure your water pump failed causing your timing belt to go with it. that's usually how it goes. Once the water pump lets go the timing belt becomes 'comtaminated" and has to be changed. You have to romove the timing belt to change the pump anyway so it all makes sense. -------------------- |
QUOTE(Hanyo @ Apr 27, 2007 - 7:31 PM) [snapback]551686[/snapback] when was the last time you change your water pump. I'm 90% sure your water pump failed causing your timing belt to go with it. I got it both timing and water pump replaced when i got the new motor back in march of 2006. I do not drive the car hard either. |
Enthusiast ![]() ![]() ![]() Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) ![]() |
That last pictutre is exactly how not to chain a car down on a flatbed, is your front bumper still attached?
QUOTE(laff09 @ May 3, 2007 - 7:50 AM) [snapback]553652[/snapback] That last pictutre is exactly how not to chain a car down on a flatbed, is your front bumper still attached? Yeah it is still attached. The reason i asked the driver to chain it like that is because the "hooks" are way up and if he would have gone under my front bumper it would have cracked my fibreglass like glass. Trust me, it has happened before. My car is so low that putting the chains under the car would make the chains tense and when going up the ramp would crush my bumper.. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) ![]() |
first your driver side wheel comes flying off, now this. I hope nothing else happens to your car man. Time to boost it while the car's temporarily outta commission. Lol.
![]() -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
hey its my twin! sorry to hear about your troubles man. atleast you arent having to return your car to stock to pass a state inspection..
![]() get her back on the road and quick!! -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
QUOTE(NgoFcukinWay @ May 4, 2007 - 9:38 PM) [snapback]554349[/snapback] first your driver side wheel comes flying off, now this. I hope nothing else happens to your car man. Time to boost it while the car's temporarily outta commission. Lol. ![]() I will keep my fingers crossed and hope that not another bad thing happens to my car... QUOTE(celicast3sgte @ May 4, 2007 - 10:36 PM) [snapback]554363[/snapback] hey its my twin! sorry to hear about your troubles man. atleast you arent having to return your car to stock to pass a state inspection.. ![]() get her back on the road and quick!! Hey man, i saw that you got the front bumper. It looks good, I can not wait to see it all done. But my car is already back on the road, I actually got it fixed last Saturday (04/27). I am hoping to have boost some time SOON!!![u] |
Lo-Fi Version | Time is now: February 20th, 2025 - 11:40 AM |
