st205 to st202 (superstrut) brakes conversion |
Apr 28, 2007 - 3:39 PM |
Enthusiast Joined Jul 17, '06 Currently Offline Reputation: 0 (0%) |
Hi all. I have recently checked out front brakes on my mate's newly bought GT4 and really liked what i've seen - bigger disks and much bigger calipers - tempting !
Has anyone ever tried fitting st205's front brakes to a st202 with a superstrut?? Just want to know if that is possible... Thanks a lot! -------------------- TRD -ST205- [color="#4B0082"][/color][size="5"][/size][font="Palatino Linotype"][/font] |
Apr 28, 2007 - 5:08 PM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Its will be a straight swap without any problems. check Maikl profile - he fitted GT4 brakes on his SSIII.
SSIII and GT4 (basicly all ST202 with superstrut) share the same structure of the front suspension components, and they can be interchargible between ST202 and ST205 without any problems. Exept springs are different on ST205 (they are stiffer, and have a little bit different spring ration) -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Apr 29, 2007 - 3:18 AM |
Enthusiast Joined Dec 15, '06 From Lithuania, Europe Currently Offline Reputation: 0 (0%) |
QUOTE(doGGy @ Apr 29, 2007 - 1:08 AM) [snapback]551948[/snapback] Its will be a straight swap without any problems. check Maikl profile - he fitted GT4 brakes on his SSIII. SSIII and GT4 (basicly all ST202 with superstrut) share the same structure of the front suspension components, and they can be interchargible between ST202 and ST205 without any problems. Exept springs are different on ST205 (they are stiffer, and have a little bit different spring ration) So another question, are SS-II, SS-III and Euro-spec GT brake system the same? I mean discs, calipers and so on. -------------------- |
Apr 29, 2007 - 9:05 AM |
QUOTE(doGGy @ Apr 28, 2007 - 5:08 PM) [snapback]551948[/snapback] Its will be a straight swap without any problems. check Maikl profile - he fitted GT4 brakes on his SSIII. SSIII and GT4 (basicly all ST202 with superstrut) share the same structure of the front suspension components, and they can be interchargible between ST202 and ST205 without any problems. Exept springs are different on ST205 (they are stiffer, and have a little bit different spring ration) Thanks man! Was almost sure it is the scenario but needed another opinion I'll ask Maikl if he is happy with his conversion. So the Lower Ladder Frame (Cusco, etc.) should also fit, correct? Thanks again! -------------------- TRD -ST205- [color="#4B0082"][/color][size="5"][/size][font="Palatino Linotype"][/font] |
Lo-Fi Version | Time is now: January 11th, 2025 - 5:18 PM |
