> oxidized paint?
post Apr 28, 2007 - 9:11 PM
cwlevie21
Joined Jan 14, '07
From Little Rock, AR
if this is even oxidized paint or not is there a way i can buff it out or somethin, or do i just need a new paint job? i think its cause the person who had it b4 me never washed it and let it sit in the sun to long w/e it was wet...? when i scratch the white lookin stuff it seems like it comes off but that would take forever and idk if im makin it worse or not...
post Apr 28, 2007 - 9:27 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
rule of thumb is to wax your car once a month to keep it from oxidizing
post Apr 28, 2007 - 9:42 PM
cwlevie21
Joined Jan 14, '07
but i bought it that way...any way to fix it to look half decent till i get the $$ for paint job?
post Apr 29, 2007 - 6:06 PM
jdmart
Joined Mar 7, '07
From dallas texas
my car is the same boat so someone help us plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
DRIVE UP..........
ACCEPT THE CHALLENGE.........
DESTROY YOUR OPPONENT.........
post Apr 29, 2007 - 11:34 PM
6strngs
Joined May 12, '06
From Wilmington, NC
mine is the same way on the hood and roof. bought it that way. and it's getting worse over time. I would wax the car but somebody said that would make it worse.
post Apr 29, 2007 - 11:48 PM
95celgt
Joined Oct 5, '03
From South TX.
try tire shine, or interior shine, and then buff it with a cloth, it worked on my old ST and it would last through the week...
post Apr 30, 2007 - 12:16 AM
Hanyo
Joined Aug 16, '03
From Bay area
they make chemicals that eat away the top layer of paint. I dont recomend this for other parts of the car. I'm assuming the old paint is not salavagable.
after you use it. you need to wash it off and use sealer and wax to buff it back to a shine.
It wont look like clear coat. But I wont be as ugly.
post Apr 30, 2007 - 1:17 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Hanyo @ Apr 29, 2007 - 10:16 PM) [snapback]552360[/snapback]
would this work for severe oxidation? I'm thinking it would only work for the beginning stages of oxidation where only your clear coat is gone.
post Apr 30, 2007 - 3:34 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE(6strngs @ Apr 29, 2007 - 11:17 PM) [snapback]552371[/snapback]
it depends on the chemical, and if there is still your orginal paint under the oxidation. I mean it wont work if your paint has oxidize all the way to the primer.
And if its bad enough you can do a second or third coat of it, maybe let it sit for a couple minutes. But remember this stuff is very harmful to paint. Dont use it too often or it will eventually eat all your paint up.
post Apr 30, 2007 - 7:27 AM
tim86
Joined Oct 31, '03
From Orlando, Florida
post Apr 30, 2007 - 10:37 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(Hanyo @ Apr 30, 2007 - 1:34 AM) [snapback]552381[/snapback]
maybe I'll give it a try. I'll be repainting the car anyway so I have nothing to lose. it can't look any worse then it already does. I'm through all the coats of clear and like 1-2 of the base color coats. I can still see green but it's a lot darker than the rest of the car.
post Apr 30, 2007 - 12:38 PM
Insanity-74
Joined Jan 9, '05
From Under the car
Is there a close up of the paint?????
Could be condensation getting between the paint and the clear coat.
or the paint might need conditioning.
Start by giving it a good going over with T-Cut...if that does no good then........
If your feeling brave then try rubbing it down with the finest wet and dry you can get (1200grit with lots of water IIRC) then T-Cutting it followed by the usual polishing methods. Go easy though as you dont want to rub right through the paint to the primer layer.
Lo-Fi Version Time is now: January 11th, 2025 - 12:54 PM
