> Weird Brake Sound?
post Apr 29, 2007 - 3:47 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
I noticed that when i apply the brakes, even lightly.. it makes a weird sound... kinda like a chukchukchukchukchuk sound... does anyone have any ideas?
This post has been edited by elvasoshexai: Apr 29, 2007 - 3:47 PM
06 Civic EX
My For Sale Thread
post Apr 29, 2007 - 4:09 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
warped rotors?
Sounds like thats ur problem.
-dave
0111011001101001011100110111001101101001
Chrome wont get ya home
post Apr 29, 2007 - 10:24 PM
bindertch
Joined Aug 18, '04
From Silverdale, WA
Does the car or wheel shake also? If not then look for something that is rubbing in the area of one of the brakes. A brake inspection at a shop would find it.
post Apr 30, 2007 - 7:21 PM
elvasoshexai
Joined May 16, '05
QUOTE(bindertch @ Apr 29, 2007 - 11:24 PM) [snapback]552323[/snapback]
no shaking... at least i didn't notice any when i tried the other day
06 Civic EX
My For Sale Thread
post Apr 30, 2007 - 9:12 PM
mr_dude
Joined Feb 16, '04
From San Diego
Good news it's not shaking, no warped rotors of messed up calipers.
If it's just a noise, check your pad thickness. On most pads, the clip that holds them in scrapes the rotor when they're worn down. It's the "replace me" noise.
post Apr 30, 2007 - 10:48 PM
elvasoshexai
Joined May 16, '05
could it just be build up or sumthing on the rotors since i haven't driven it for 4 months while at school? and it should go away after a bit of braking?
cause it doesn't do that when i brake hard...
06 Civic EX
My For Sale Thread
post Apr 30, 2007 - 11:23 PM
mr_dude
Joined Feb 16, '04
From San Diego
QUOTE(elvasoshexai @ Apr 30, 2007 - 8:48 PM) [snapback]552714[/snapback]
Any buildup should disappear after your first hard brake. Generally if you leave your car sitting the rotor metal will rust, but it'll all disappear the first time you brake. The sound going away when you brake hard is consistent with the wear indicator.
Check your pads, if this is new to you see the photo below. The object on the right is the caliper with two pads that have about half an inch of thickness left. If there's not much pad between the metal plate and your rotor, you definitely need to replace the brakes. And that should fix your noise problem.
post May 2, 2007 - 5:35 PM
GTS13
Joined Apr 14, '06
From Vancouver, WA
I had that once, and it turned out that a pad actually just fell off...don't ask me how, but it definitely wasn't there anymore. Check to make sure your pads are still there before you do any more serious damage to your rotor.
post May 2, 2007 - 8:12 PM
mr_dude
Joined Feb 16, '04
From San Diego
QUOTE(GTS13 @ May 2, 2007 - 3:35 PM) [snapback]553406[/snapback]
Hah! Yeah, not having a pad counts as zero thickness. PM me or email me or something if you don't know how to check your pads.
Lo-Fi Version Time is now: January 11th, 2025 - 2:48 AM
