![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) ![]() |
So yea... my car has been almost stalling when I am starting and in second gear....at first i thought it ws the IAC...I have not cleaned it but Im sure that is not the problem...I was just messing aroudn the other day with my friends and tried to burn out (yes I know I have an ST) I use to be able to tweak the tires no problem...That is not the case anymore..=[.... So I tried an dthe car went but did not jump off the line like it used too...just kinda slowly went up in speed.. and then I smelt the clutch...I was hoping it was just glazed over or something so I drove it around and tried again...same thing...At this point my car is still drivable but I know its only a matter of time now....So any can anyone recomend a good clutch setup for the 1.8l I was thinking of going with ACT but its kinda pricey...and how do you guys feel about changing the flywheel or should i just get it resurfaced...
![]() This post has been edited by Daftboy: Apr 30, 2007 - 11:01 AM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
No one knows?
Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) ![]() |
For an ST the standard clutch is fine, but if you want something a little stronger...RPS do an extensive range of clutches varying in type and torque capability. The organic clutches they do have good pedal feel and drivability.
Definately get the flywheel resurfaced at the very least. Lightweight alloy flywheels are good, but maybe a little overkill for an ST (no offence). spend the money on performance/handling mods instead |
I wanted something witha little more bite in it... I think I will go with a stage 1 or 2 not yet sure thou.
This post has been edited by Daftboy: Apr 30, 2007 - 1:00 PM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
No one recommends any other brands....?
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
our weak 7afe motors need all the help they can get.. look for an RPS clutch/flywheel combo maybe? lightweight alum. flywheel
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
The RPS clutches go very well wit Fedanza fly wheels
How many puck you think i should get ?..I was thinking 4 should be fine.
This post has been edited by Daftboy: May 1, 2007 - 8:33 AM -------------------- ![]() --------------------------------私は銀行に漂う,TRD Inspired |
I wouldnt get a puk clutch, they are a pain in the arse to drive with off the track...i`d go for an organic clutch
Lo-Fi Version | Time is now: February 23rd, 2025 - 8:03 AM |
