> jumpy rpms, rpm's gone wild!!
post Jul 21, 2003 - 11:07 PM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
I noticed today that my rpms jump up and down when I give it gas around the 2500-3000 rpm range. My throttle cable needs to be replaced,could that be the problem???? I just need some help.
post Jul 22, 2003 - 12:35 AM
why does ur throttle cable need to be replaced?
ur RPMs wouldnt jump, they'd probably just stick.
This post has been edited by Supersprynt: Jul 22, 2003 - 12:36 AM
post Jul 22, 2003 - 10:31 PM
95STHATCH
Joined Jun 21, '03
The throttle cable sticks at low rpms and thats why I need to replace it but,when I give it gas in lets say 5th gear while its between the 2500-3000 rpm range it will jump uplike i want it too but then a split second later it will drop back down then jump up and down again.
post Jul 30, 2003 - 9:12 PM
t96f
Joined Sep 30, '02
From NS Can
Sounds like slipping clutch!!
post Jul 30, 2003 - 9:42 PM
95STHATCH
Joined Jun 21, '03
Would it be slipping in 5th and not be slipping in 1st? It might be a stupid question because i've only been driving a 5 speed fpr about a month.
post Jul 31, 2003 - 12:25 AM
t96f
Joined Sep 30, '02
From NS Can
you didn't say was only in 5th and not first LOL
post Aug 4, 2003 - 12:08 AM
Stealths95GT
Joined Apr 19, '03
From Washington
need new clutch....
post Aug 5, 2003 - 10:44 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
are you sure you are not getting a miss somewhere. I had a similar problem and it turned out to be a bad spark plug. you should check the easy stuff like that b4 you go and jump into bigger jobs like replacing the cluch! ask someone who knows a little about engines to listen to the car idle then if you have to take them for a ride so they car feel it. Best way to diagnose a problem is to get many ideas and then start with the easy ones first and work through all ideas 'till the prob is gone.
Lo-Fi Version Time is now: November 24th, 2024 - 8:23 AM
