need help big time |
Apr 30, 2007 - 5:06 PM |
Enthusiast Joined Feb 27, '07 From cape coral/ft myers florida Currently Offline Reputation: 7 (100%) |
ok so i got my new turbo in and i have the vac line from the wastegate on the bottom of the boost controller and the other hooked up to my vac system ........ when i take off its not opening the wastegate and constantly building boost so i switched the lines and its still doin the same thing ....... what am i doin wrong??
-------------------- BOOST GETS YOU LAID!!!! |
Apr 30, 2007 - 5:14 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
QUOTE(jesterwr217 @ Apr 30, 2007 - 5:06 PM) [snapback]552594[/snapback] ok so i got my new turbo in and i have the vac line from the wastegate on the bottom of the boost controller and the other hooked up to my vac system ........ when i take off its not opening the wastegate and constantly building boost so i switched the lines and its still doin the same thing ....... what am i doin wrong?? What kind of boost controller? Ball & Spring? The one on the bottom (ball side) must be connected to the compressor housing of the turbo. The one on the side (of the spring) must be connected to the wastegate actuator. If you have 2 port actuator (like CT26), you will need to cap the other port. -------------------- _Gary
Apr 30, 2007 - 5:22 PM |
QUOTE(Gary @ Apr 30, 2007 - 6:14 PM) [snapback]552597[/snapback] QUOTE(jesterwr217 @ Apr 30, 2007 - 5:06 PM) [snapback]552594[/snapback] ok so i got my new turbo in and i have the vac line from the wastegate on the bottom of the boost controller and the other hooked up to my vac system ........ when i take off its not opening the wastegate and constantly building boost so i switched the lines and its still doin the same thing ....... what am i doin wrong?? What kind of boost controller? Ball & Spring? The one on the bottom (ball side) must be connected to the compressor housing of the turbo. The one on the side (of the spring) must be connected to the wastegate actuator. If you have 2 port actuator (like CT26), you will need to cap the other port. its a hallman controller but i dont have a vac source on the compressor housing mine runs into my regular vac system -------------------- BOOST GETS YOU LAID!!!! |
Apr 30, 2007 - 5:27 PM |
Does your car boost normally WITHOUT the MBC?
Apr 30, 2007 - 5:28 PM |
no i tryed that too and it overboosted
Apr 30, 2007 - 5:36 PM |
What turbocharger is this? CT26?
Did you cap the other port on the actuator? Which port on the manifold did you connect the hose to? -------------------- _Gary
Apr 30, 2007 - 5:56 PM |
t3
it only has one port and the vaccum line that the fpr is hooked into -------------------- BOOST GETS YOU LAID!!!! |
Apr 30, 2007 - 6:03 PM |
wtf!!!!! i just turned the boost gauge all the way down and its still boosting??
Apr 30, 2007 - 6:05 PM |
ehum
wastegate goes to atmosphere on top... correct? ie: http://www.tialmedia.com/documents/w3_tial_wginstall.pdf This post has been edited by Consynx: Apr 30, 2007 - 6:06 PM -------------------- |
Apr 30, 2007 - 6:11 PM |
mines internally gated
Apr 30, 2007 - 6:17 PM |
Look like your wastegate is seizing.
Try moving the rod back and forth abd see if it's stuck. Better yet, if you have an air compressor (or a bike pump), hook that up to the actuator and see if the rod moves when you applying pressure to it (say 10 psi) -------------------- _Gary
Apr 30, 2007 - 6:27 PM |
i ordered the turbo from turbokits.com and i ordered it without the actuator (which it says on the invoice) but it showed up with one on it but i didnt test it out is it possible that they sent me a dummy actuator??
Apr 30, 2007 - 8:17 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(jesterwr217 @ Apr 30, 2007 - 4:27 PM) [snapback]552630[/snapback] i ordered the turbo from turbokits.com and i ordered it without the actuator (which it says on the invoice) but it showed up with one on it but i didnt test it out is it possible that they sent me a dummy actuator?? -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Apr 30, 2007 - 8:36 PM |
you should have a line going from your turbo to your WG actuator. then your boost would depend on your wg spring
Apr 30, 2007 - 8:56 PM |
QUOTE(lagos @ Apr 30, 2007 - 9:36 PM) [snapback]552666[/snapback] you should have a line going from your turbo to your WG actuator. then your boost would depend on your wg spring there isnt a vacum port on the turbo....i was told i can use the vacum source im using -------------------- BOOST GETS YOU LAID!!!! |
Lo-Fi Version | Time is now: November 30th, 2024 - 3:33 PM |
