> Quick question about sub boxes, Just curouis
post Apr 30, 2007 - 7:16 PM
pepsiman
Joined Jun 3, '06
im thinking about getting a pioneer 10 inch sub and i have read about how premade boxes are bad. I was thinking of making a box (with alot of dad's help lol) or getting a build a box thing from walmart. Ive read many times that premade boxes are bad since each sub need its own uniqe amount of airspace and the recomended amount of the pioneer is 0.65 ~ 1.25 Cubic Feet and the build a box is .75 cubic feet. So does that mean the build a box would be ok or would i be better off building one?
here is the links two the box and the sub:
http://walmart.scosche-cars.com/products2/...3#Similar+Items
http://www.pioneerelectronics.com/pna/v3/p...etailsComponent
thanks
post Apr 30, 2007 - 11:03 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
BUILD A BOX = GARBAGE!!! don't even think about buying, 10" box from best buy will do just fine, i think most of their's are 1.00cu ft, if you don't want to pay that money then build your own, 3/4 MDF <-- this is a must, make sure you measure the interior volume not exterior, and DOOR/WINDOW sealant from lowe's works amazing to seal it, put it on your finger and push it into all the joints, pre-drill holes, then use screws
Breaking Axles...
post May 1, 2007 - 3:26 PM
pepsiman
Joined Jun 3, '06
lol ok that pretty well answers my question it would probably be alot higher quiltiy and custom fit to wherever i put it if it was homemade. thanks for the reply
post May 1, 2007 - 4:08 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
If you make a home made, you can also decide how big or small you want your box to be, not to mention the shape. If you push for the larger sized box, you will have deeper bass but less response on the high end and if you get a smaller box you will have better response in the higher end. Something in the middle is usually best, as in your case 1.00 cu ft.
I also recommend 3/4" MDF, screws (countersink them) and some sealant or silicone for all seams and screw holes. Internal bracing can help, but I don't think you would need this for one 10" unless you made a big box. Also, a layer of cotton batting inside the box (the stuff used to make quilts) can help to smooth out the bass response.
Lo-Fi Version Time is now: November 27th, 2024 - 2:22 AM
