Enthusiast Joined Apr 11, '07 From Lafayette, IN Currently Offline Reputation: 0 (0%) ![]() |
OK so I started my rebuild project a month ago, working on it after classes and work and I need some help on two harness I cannot place.
The car is a '95 Celica ST (California) Both wires are on the intake side. 1. On the same wire cluster as the downstream 02 sensor, and a lead to a vacuum control switch. Two prong connector (black/red and brown wires). 2. Out of the injector wire harness (the solid black plastic box under the intake). One prong connector (blue-ish wire). Can anyone help me with what these goto? I've been staring down there for an hour or so and cannot see any clips that need a harness. Also if anyone knows where I can find some good information on the vacuum line routing (EGR, EVAP...etc.) and wire routing could you please post it? Thanks for your help in advance. |
Lo-Fi Version | Time is now: February 22nd, 2025 - 8:24 PM |
