> Loose A - Arm, I need someone to confirm I am pooched
post May 1, 2007 - 7:20 PM
qatar11
From Lake Orion, MI
So I have a 6G That I was going to get back on the road so I can get rid of my POS SVT Focus (which is for a different rant). The reason I bought the fukkus is because the Celica had a loose A-Arm as a result of some bad judgment in "speeding up" the process of a clutch replacement.
Basically We tried to remove the A-Arm from the sub frame as opposed to taking the knuckle apart to remove the drive axle. At some point in backing out the bolt that holds the A-Arm to the sub frame (also the hinge point) the nut that I assume is welded inside the sub frame busted loose and the bolt is now extremely loose and the entire A-Arm can float 2 - 4" in many unfriendly directions. This of course has resulted in a lot of angry noise and 4 destroyed tires if you try to drive on it.
I just want a few other people to confirm that I am in fact up ****s creek and I will tear out the front end and get my ST205 conversion started up...
So take a look at these pics so you can see the problem area in question
aforementioned ST205 Bits
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 3, 2007 - 7:23 PM
mike, you'll need to cut and re-weld the nut in place, if you can.
my cousin just went thru this on his duece.
the rear crossmember for that runs 600+ @ toyota..lmao
Lo-Fi Version Time is now: January 10th, 2025 - 9:06 PM
