Installing start button question [Update: pics added] |
May 2, 2007 - 6:02 PM |
Enthusiast Joined Mar 25, '07 From Holland Currently Offline Reputation: 0 (0%) |
I just bought a S2000 style start button and tried to install it but i dunno which wires to tap from.
2 wires should go from the starter solenoid to the relay of the button. Start: black/white Ignition #1: Black/orange Ignition #2: Blue/red Accessory: grey Constan +12 volts: white I tried Ignition #1 and #2 and nothing happened. So then I tried ignition #2 and start, then my fuse burned out twice. I haven't tried ignition #1 and start yet cus i dont wanna burn another fuse. help me guys.... This post has been edited by djseven: May 9, 2007 - 7:15 PM |
May 2, 2007 - 6:51 PM |
Enthusiast Joined Aug 29, '02 From Lake Orion, MI Currently Offline Reputation: 6 (100%) |
Do you have to put the key in run first then push this red button? How many contacts are in the back of this switch? What kind of current can this switch handle? Its been a while since I looked at that part of the system but I think some pretty heavy gauge wire runs through the "run" "start" connections
-------------------- -Mike
mjcoury@gmail.com Team Reynolds Style Celica Blog Celica Wiki It will take him a moment to realize that he's about to make a 180 degree turn at speed, but you will be ready for it. Brace for the g's, and fast heel-toe work. |
May 2, 2007 - 6:57 PM |
yes i need to put the key in first. relay has 4 wires. 2 of them comes from the ignition barrel 1 goes to the start button and 1 goes to the - of my cigarette lighter. so the + goes from the button to the + of the lighter. im not sure what u mean by current of the switch...sorry my english is bad
and another weird thing...i also wired my indiglo gauges to my lighter and when i push the start button, the gauges will glow lol |
May 6, 2007 - 6:14 PM |
I got it....i needed to connect constant 12v with start (i couldve known this actually ) I'll make pics soon.
May 7, 2007 - 11:05 AM |
Enthusiast Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) |
constant 12v? dont think you need that. connect the white black & black/orange or just black to the relay and thats it.
so basically you wire it like this: 12v swiched live to pin 30, wire out to starter to pin 87,push button switch ,pin 86, ground to pin 85. ...the problem with these switch is when the engine already started if you press it again it will kill the engine...im working one a second relay so that when the engine started it wont die if you press the switch again...only works when the engine is off. i think i need some diodes....LOL This post has been edited by lubu: May 7, 2007 - 11:36 AM -------------------- 98% completion --- aaRon |
May 7, 2007 - 11:16 AM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Pix please ......One thing thou...whats the point of having that button if you still need to insert the key?
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
May 7, 2007 - 12:14 PM |
the key is to feed 12+ to the relay plus it acts as a security device,
here is the pic This post has been edited by lubu: May 7, 2007 - 12:27 PM -------------------- 98% completion --- aaRon |
May 9, 2007 - 7:00 PM |
so here are the pics...
this is my race mode button, it adds aprox 15hp if activated this is the start button...i quite like the look. ive put the cigarette lighter in dashboard. what do u think of it? @lubu: i havent connected the way you said cus im a bit lazy now hahaha. i know its better...maybe later I like the idea to protect the button from pressing it twice causing the engine to stop. tell me how ur planning to do so with a second relay. |
May 9, 2007 - 7:14 PM |
more pics here....i just luv it kakaka
May 9, 2007 - 7:58 PM |
Enthusiast Joined Sep 18, '05 From NW North Carolina Currently Offline Reputation: 4 (100%) |
Question. What does your "race mode" button connect to that gives you the extra 15hp? Piggy-back ECU?
May 9, 2007 - 8:07 PM |
it connects to the air intake sensor. i do need a powerfilter and 98octane to make advantage of full 15hp
May 9, 2007 - 9:15 PM |
air intake sensor? you mean you hook it up to the switch a resistor in the loop?
May 10, 2007 - 6:42 PM |
no, the race mode button is connected directly from a relay to the 2 wires of the air intake sensor.
May 10, 2007 - 7:33 PM |
Enthusiast Joined May 15, '05 From Toronto Currently Offline Reputation: 4 (100%) |
:S i cant see the pictures.
May 11, 2007 - 3:07 PM |
i cant see how you gain 15hp by connected directly to the sensor...maybe if you throw in a resistor then maybe...
May 11, 2007 - 3:12 PM |
I can't see any of your pix
May 11, 2007 - 3:41 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
Those "Race mode" buttons are a joke, you can damage your engine using them long term. If it was so cheap and easy to add 15 BHP, do you not think Toyota would have done it originally?
That button works about as well as your pix. This post has been edited by manphibian: May 11, 2007 - 3:42 PM -------------------- |
May 11, 2007 - 3:58 PM |
Enthusiast Joined Dec 16, '06 From Maryland Currently Offline Reputation: 0 (0%) |
what happend to the pics!!!!!!! i wanna see the button This post has been edited by DSToyo: May 11, 2007 - 3:58 PM |
May 11, 2007 - 8:22 PM |
do not use the resistor across the sensor...while it might work by tricking the ecu to think that the air flow is colder....not very efficient. You'll damage in engine in the long run bcoz the fuel ratio mixture is not optimised, more fuel than it should be...
May 12, 2007 - 2:10 AM |
Enthusiast Joined Mar 13, '07 From Gold Coast, QLD, Australia Currently Offline Reputation: 0 (0%) |
QUOTE(lubu @ May 12, 2007 - 11:22 AM) [snapback]556676[/snapback] do not use the resistor across the sensor...while it might work by tricking the ecu to think that the air flow is colder....not very efficient. You'll damage in engine in the long run bcoz the fuel ratio mixture is not optimised, more fuel than it should be... Yeah I tried it a resistor once, smelled how rich the engne was running and promptly took it off! I just finished my cold air intake and now I now what real +HP is! |
Lo-Fi Version | Time is now: January 17th, 2025 - 3:38 PM |
