![]() Enthusiast ![]() ![]() Joined Mar 22, '07 From Greenville NC Currently Offline Reputation: 0 (0%) ![]() |
ok, i am about to start sourcing parts to build my own turbo kit but i need to know what will and what wont work with the 7AFE engine. i have read about the b-16 turbo manifold can be used but it has to be custom fabbed a bit, that wont be too much of a problem, what is the best turbo you guys could recommend? my budget isnt too tight, but its not that big, the cheaper the better, im not looking to put down 200 horses or anything i just want to come close to about 150ish. i have a buddy that can sell me FMIC cheap he works at a performance parts store and the intercooler was used as a demo. but other than that what would you guys suggest for me to order?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '06 From New Jersey Currently Offline Reputation: 105 (100%) ![]() |
Enthusiast ![]() Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) ![]() |
personally, i would go for T28 turbo from S15
![]() Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) ![]() |
if that is all the hp you want i would go with a t3 with a .48 / .42ar trim it will give you 7psi-10psi and spool pretty quick , if you want a quick street car ( light to light ) if you are looking at a high top end spead then go with a t3-t4 .50-.57 trim you wont spool as quickly but up in higher rpms you will have more push . that is just my .02 cent and good luck with what ever you get.
Lo-Fi Version | Time is now: February 21st, 2025 - 5:11 PM |
