> How to Remove Valve Cover??, so I need to get my valve cover off, but can't figure out how. I t
post May 6, 2007 - 9:20 PM
NapTown94
Joined Jan 19, '07
From Indianapolis
so I need to get my valve cover off, but can't figure out how. I took out all the screws and what not, tried moving it with a rubber mallet...but to no avail. can someone tell me how to get it off?!?! photos would be a huge help, as I learn everything visually.
post May 6, 2007 - 9:42 PM
94celicadude
Joined Mar 28, '04
From St.Louis
QUOTE(NapTown94 @ May 7, 2007 - 2:20 AM) [snapback]554809[/snapback]
did you pull out your spark plug leads? also, make sure that the cables running over the top are out of the way. Hope this help.
1994 GT Hatchback
1994 ST Coupe
1988 Corolla Wagon All-Trac
1999 Corvette
2008 Cobalt SS Turbo
post May 7, 2007 - 4:34 AM
Justin
Joined Dec 13, '03
From Alabama
You're probably gonna have to cut the valve cover gasket inbetween the head and the cover with a razor blade. I had to do the same thing. After I had ab half of it cut it came off.
post May 7, 2007 - 7:37 AM
mikeismad0408
Joined Mar 22, '07
From Greenville NC
x2 on the cutting the gasket, if that doesnt work then just keep hitting it with the rubber mallet, but hit the corners, it just has a really tight vacuum seal on it.
post May 7, 2007 - 8:32 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
Yea that sounds like what happened to me I had it all off and didn't have an extra seal...So I just left it on....I still need to go get one and redue the seals.
post May 7, 2007 - 3:53 PM
WALKER
Joined Mar 29, '06
From Regina, SK, Canada
This might help?
post May 7, 2007 - 7:04 PM
mikeismad0408
Joined Mar 22, '07
From Greenville NC
he has a 7a not a 5s so that wont help him too much, just make sure you have all the bolts undone from the top and then try and hit it. you have to unbolt your cable from your alternator so you can pull the valve cover off.
post May 8, 2007 - 8:57 AM
WALKER
Joined Mar 29, '06
QUOTE(mikeismad0408 @ May 7, 2007 - 6:04 PM) [snapback]555121[/snapback]
Sorry, got ahead of myself. Best of luck!
Lo-Fi Version Time is now: February 20th, 2025 - 12:52 AM
