4 Pages V   1 2 3 > »
> Few issues
post May 6, 2007 - 10:42 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
From the begining of my swap I've had low vac issues. I replaced hoses tightened everything up capped off holes.
I eliminated my AC and power steering. I have the hose for the AC idle up capped. Would I be better off capping the two PS vac lines?(current setup) Or should I connect them to each other with a hose. I'm close to having full vac, but its still alittle off.
Second thing, when I slow down and put the car into neutral the RMP's dip way below normal idle. After running at like say 650-750 rpm for a few seconds, it raises back to 1000 where its been since the begining of this project. Sometimes the car stalls, I looking for some suggestions or ideas.
I've checked timing, its set at 10d's.
Thanks guys
I will return one day.
post May 6, 2007 - 11:03 PM
95celgt
Joined Oct 5, '03
From South TX.
man, for some reason my 3s has crappy vac as well, when I did the re-build i changed every vac hose and it still sucks, when i turn it on its only at 10vac and once it warms up the best it does is 15 vac, so im still trying to figure out if the ecu or something like a vsv or afm can affect it this bad........
post May 6, 2007 - 11:13 PM
did you ever do a boost leak test?
post May 7, 2007 - 6:39 AM
alltracman78
Joined Aug 9, '06
From Ma
A boost leak won't affect idle quality at all.
A vacuum leak will however.
Jeff, if you join those 2 hoses you will raise your idle.
One gets air from before the TB [intake hose] while the other runs off the intake manifold.
Basically you will be creating a second ISC valve, but with no valve.
For both of you, how does the needle in the gauge look?
Is it steady at low pressure or does it jump around some?
If it's steady it's more of a general problem, such as a weak coil, or vacuum leak. Or a worn out engine.
If it's jumping around it's more likely to be from 1 cylinder, such as a bad plug, worn ring, or bad seal on a valve.
post May 7, 2007 - 9:07 AM
a boost leak test will find leaks in the system. from vac lines to IC couplers. any vac/boost leaks on a 3s will play a big role in how the car idles, because youll always be sucking in air that the afm cant account for.
post May 7, 2007 - 9:37 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE(alltracman78 @ May 7, 2007 - 7:39 AM) [snapback]554901[/snapback]
A vacuum leak will however..
That sounds like an oxymoron,
Jeff, what is your vacuum at idle? it should be around 18-20 Hg with stock cams.
I only have 10 Hg vacuum at idle but thats because of the cams.
also if your going by the marks on the crack to determine timing it might be wrong.
my crank pulley was around 4 degrees off from tdc.
But it does sound like a boost/vacuum leak ( Depending if you boosting or at idle biggrin.gif )
post May 7, 2007 - 9:39 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I've done the boost leak test. I'm almost sure I dont have any major leaks. I have a very small leak now. I just cant seem to find it.
Whats funny is that I disconnected my Autometer boost gauge. After that my vac was perfect. I went for a ride boosted alittle, came back my vac was in its current state. Just a little off.
Freakin weird man. I can't seem to shake this vac issue.
post May 7, 2007 - 9:44 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
John, at this point I'm not sure what my vac is.
The reason why, I disconnected my Autometer boost guage. Leaving me with the Greddy boost controller reading my vac and boost pressures. The problem is the Greddy reads in some system I'm not familiar with laugh.gif
It reads between -95 to -99. -99 is perfect vac. But it fluxuates between those numbers. Its never solid on one number.
post May 7, 2007 - 9:46 AM
when you did your boost leak test, how many psi of air were you able to fill it up to? did you spray everything down with soapy water and watch for bubbles?
there is a very strong chance that the leak is coming from the boost gauge. the nylon hose can crack during installation or your compression fittings might be leaking. another thing to check for is your intake piping, the idle hose that leads all the way to the throttle body, or your distributor oring. those can be tricky to find.
post May 7, 2007 - 9:54 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(lagos @ May 7, 2007 - 10:46 AM) [snapback]554928[/snapback]
20 psi I sprayed everything with soapy water. After I was done I could only hear a very faint hiss from one of the valves on the throttle body. I can't remember the name of this valve at this time, my brain is not working today. I heard that was normal to have some air coming from there.
After I removed the Autometer with the nylon line, the vac was perfect. After a quick ride it fell a few numbers to like -95 -97. I should be at -99.
post May 7, 2007 - 9:58 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Anybody have a vac diagram of a jdm 3sgte ? The celicatech BGB has usdm.
post May 7, 2007 - 10:16 AM
have you checked the rubber hose right under the throttle body that goes to the idle valve?
you should also try disconnecting the harness plug that goes to that valve while the car is running, to see if your idle goes up. if it doesn't, then the valve or rubber hose going to it is the problem.
another thing to take a look at is your throttle position sensor. . if thats not plugged in or has been messed with, youll get high idle and that in turn will mess with your vac reading.
This post has been edited by lagos: May 7, 2007 - 10:21 AM
post May 7, 2007 - 10:23 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(lagos @ May 7, 2007 - 11:16 AM) [snapback]554945[/snapback]
I dont know, I might have. I wish I had a JDM vac diagram so I can point out everything that I changed and things I capped off. I'm just not sure if I changed it with out looking at the engine. The engine is kinda far away right now.
I know I changed one fat hose under the TB that connects to the vac pipe. There is only three hoses on the bottom of the TB two for coolant and one for vac right ?
Isnt there a way to test it ? The TPS.
post May 7, 2007 - 10:26 AM
there are bgb multimeter tests for the tps you can do.
if your ever around my way with your car, you can stop by and ill try to help you figure it out.
post May 7, 2007 - 10:28 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
QUOTE(lagos @ May 7, 2007 - 11:26 AM) [snapback]554948[/snapback]
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
http://opc.mr2oc.com/online_parts_catalog/...sgteVacuum1.gif
Thats what i found, hope that helps ya. its usdm but just pretend the egr system is gone.
that leak you heard is the ISC is normal.
post May 7, 2007 - 10:30 AM
QUOTE(defgeph @ May 7, 2007 - 11:28 AM) [snapback]554949[/snapback]
Jeff's Idle Problem Meet:
place: my house
Time: whenever
Attending: 1. defgeph
post May 7, 2007 - 10:31 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
post May 7, 2007 - 10:41 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
Ok I think I have this right. Some of these things I dont know what they are. They are circled. The ones with red X's are removed and vac source for thos items are capped off as close to the manifold as possible.
post May 7, 2007 - 10:46 AM
you charcole canister should not be vented to the atmosphere. it should go back to one of the hard lines that goes to the tank.
the vac valve to the right is actually your tvis system. its on the back of the intake manifold .
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: January 14th, 2025 - 7:41 PM
