> 3rd Gen 3SGTE already equipped with Shimless Bucket?, Read this on Toyota Nation
post May 7, 2007 - 1:39 PM
qatar11
From Lake Orion, MI
http://toyotanation.com/forum/t36210.html
Which states that the 3rd Gen has a "shimless bucket"
Looking at the pictures here
http://www.rossmachineracing.com/3sbucket.html
Shows the difference between the 2nd gen 3SGTE bucket and the MRS bucket
My Buckets look like the MRS bucket but with a removable shim (on the underside) that I could change to alter the thickness without buying whole new buckets.... now the only trick is to source a "shim" from somewhere shouldn't be toooo hard.
Preguntas? Problemas? Comments?
I will append my own posting.....
also from the same toyota nation posting
Q: Whats shimless or shim under bucket lifters?
A: The stock bucket weighs 1.6 oz. & the MRS(MR Spyder) weighs 1.03 oz. That is a weight savings of 35.5%. When high lift cams are used with stock lifters it has caused the shims that are used for adjusting cam/lifter clearance to fly out. This eliminates that by eliminating the shim all together. That lightens the valvetrain weight and allows higher RPM limits.
Part Number Lift
13751-23030 5.12
13751-23040 5.14
13751-23050 5.16
13751-23060 5.18
13751-23070 5.20
13751-23080 5.22
13751-23090 5.24
13751-23100 5.26
13751-23110 5.28
13751-23120 5.30
13751-23130 5.32
13751-23140 5.34
13751-23150 5.36
13751-23160 5.38
13751-23170 5.40
13751-23180 5.42
13751-23190 5.44
13751-23200 5.46
13751-23210 5.48
13751-23220 5.50
13751-23230 5.52
13751-23240 5.54
13751-23250 5.56
13751-23260 5.58
13751-23270 5.60
13751-23280 5.62
13751-23290 5.64
13751-23300 5.66
13751-23310 5.68
someone might want to sticky this info? or put it into a wiki? cough chris cough
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 7, 2007 - 10:05 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
I could have told you that... wink.gif Same goes for the n/a 3SGE's also and the 16V 4AGE versus the 20V 4AGE. Almost all of the newer toyota engines... say 92-93 and up changed over to under bucket shims... then say around 2000+ they removed the shim completely... However this information is only useful if you plan on running some really knarly cams.
This post has been edited by Kwanza26: May 7, 2007 - 10:07 PM
post May 7, 2007 - 10:17 PM
qatar11
From Lake Orion, MI
QUOTE(Kwanza26 @ May 7, 2007 - 11:05 PM) [snapback]555196[/snapback]
Well i have to re-shim everything so... I'm going to guess the MRS buckets will be easier to find - and lighter than the 3rd Gen Bucket/Shim combo
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 7, 2007 - 11:26 PM
you can get shims from toyota... at least you can for the 2nd gen.
post May 8, 2007 - 9:24 AM
qatar11
From Lake Orion, MI
QUOTE(lagos @ May 8, 2007 - 12:26 AM) [snapback]555242[/snapback]
Yessir - you can get 2nd gen shims and MRS Buckets - 3rd gen 3SGTE as I learned has shim under bucket that on first inspection is not shared with any other motor platform stateside
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 9, 2007 - 3:37 PM
Xpander
Joined Sep 5, '02
From Winter Haven, FL
You can get the shims from Toyota World, but you will need to know the Shim # and could possibly take months to get.
If you nicely ask a member from the UK, you might be able to get them much faster. Wolf TM was kind enough to offer to help me and told me each shim would be around 3.5 Euros. I lucked out and found someone local to me with a spare Gen 3 head with shims.
-Colin
post May 16, 2007 - 10:03 AM
qatar11
From Lake Orion, MI
Are the buckets different between 1ZZ and 2ZZ cause the bucket that showed up last week is too small.... it fits inside my old buckets actually.... UGH
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 16, 2007 - 5:31 PM
scothaniel
Joined May 1, '03
From Michigan
Should you find a platform that does use these shim-under buckets, let me know. I've got a fairly load valve tick that will probably need some shimming.
Scott
West Michigan
post May 17, 2007 - 9:16 AM
qatar11
From Lake Orion, MI
QUOTE(scothaniel @ May 16, 2007 - 6:31 PM) [snapback]558550[/snapback]
If I do successfully change over to these shimless buckets you are more than welcome to my old shims - I'tll cost you a 6 pack of Oberon or so....
-Mike
mjcoury@gmail.com
Team Reynolds Style
Celica Blog
Celica Wiki
post May 17, 2007 - 10:15 AM
scothaniel
Joined May 1, '03
From Michigan
Thats a deal!
This post has been edited by scothaniel: May 17, 2007 - 10:16 AM
Scott
West Michigan
post May 18, 2007 - 12:20 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(qatar11 @ May 16, 2007 - 3:03 PM) [snapback]558344[/snapback]
They're not listed as different in my books... so maybe not... although I tend to think they would be different. The 2ZZ/1ZZ buckets are listed to be 31mm compared to the 3SGTE (1994 MR2 turbo specs) at 28mm.
Lo-Fi Version Time is now: January 15th, 2025 - 2:38 PM
