> lifters *edit* need help, on a 95 st
post May 7, 2007 - 5:32 PM
Redline08
Joined Feb 23, '07
From Albany, NY
Does the 7A on a 95 celica st have lifters?
i got something clicking and just wondering if it could be them...
*edit* lifters are clicking how do i fix that,
seafoam, valve treatement, and ATF didnt work, arggg
This post has been edited by Redline08: May 8, 2007 - 7:36 PM
post May 7, 2007 - 7:14 PM
alltracman78
Joined Aug 9, '06
From Ma
Yes.
It is what the shims sit on.
They are bucket lifters, and look like their name.
They probably are what is ticking, Toyota engines are notorious for this.
You can check the clearance, but normally they don't go out of spec, even on high mileage engines.
post May 7, 2007 - 9:37 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Very common with Toyota's Buckets/shims. You should hear my 20V... tick tick tick. Injectors also tick a fair bit...
post May 8, 2007 - 5:30 PM
Redline08
Joined Feb 23, '07
From Albany, NY
yea its really really embarrasing, almost everyone i know says its a POS and im gonna throw a rod or a bearing any minute now,
any ideas on how to fix it, or at least quiet them a little?
(i tried ATF, didnt work)
post May 8, 2007 - 8:44 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
my injectors tick louder than my valve train. is a crisp ticking or a muffled ticking? more of tock than a tick.
tick is injectors, tock is valve train noise. you can use a screw driver like a stethoscope to listen to the topend and the injectors to figure where exactly the noise is coming from you know.
post May 8, 2007 - 9:02 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(Redline08 @ May 8, 2007 - 5:30 PM) [snapback]555476[/snapback]
Well, ask them how ticking lifters will cause you to throw a rod or spin a bearing......
And post up the answers.
They should be interesting.......
Like I [and Kwanza] told you, it's part of owning a Toyota. You just have to deal with it.
post May 8, 2007 - 10:43 PM
My motor ticks quite loudly as well...I've just grown used to it.
post May 8, 2007 - 10:59 PM
97lestyousay
Joined Jul 7, '03
The clearence adjustment should help if it is out, if it hasn't
been apart it shouldn't be out of adjustment. Is it something that just started?
This post has been edited by 97lestyousay: May 8, 2007 - 11:19 PM
JDM guy made me do it.
post May 9, 2007 - 12:03 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
my lifters are quite noisy also. i can hear them and my fuel injectors even w/ the hood closed. somtimes it'll stop after i revv though...
post May 9, 2007 - 8:58 AM
56willysnut
Joined Nov 29, '06
From Newnan, Ga.
I've got a set of 7afe rods when yours let loose.(cheap)
post May 9, 2007 - 1:52 PM
Redline08
Joined Feb 23, '07
From Albany, NY
really i cant do anything?
that sucks cause its really bad, and really embarrassing,
if it helps i noticed when the engine is cold, like right when i start her up, i dont hear any ticking
does this change the scenario any?
post May 9, 2007 - 6:22 PM
alltracman78
Joined Aug 9, '06
From Ma
Dunno man
It's REALLY hard to conclusively diagnose noises online....
You can always check the clearance, but it's normally not out.
post May 9, 2007 - 8:27 PM
Redline08
Joined Feb 23, '07
From Albany, NY
Dunno man
i can get video, it will just take a day or two, check back soon
thanks
This post has been edited by Redline08: May 9, 2007 - 8:27 PM
post May 9, 2007 - 8:56 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Redline08 @ May 10, 2007 - 1:27 AM) [snapback]555917[/snapback]
Dunno man
thanks
Check your shim cleareances... buy new shims/buckets... then *HOPE* it helps. A lot of the times... it doesn't help that much.
Lo-Fi Version Time is now: December 4th, 2024 - 2:36 PM
