![]() Enthusiast ![]() ![]() ![]() Joined Feb 18, '07 From So Cal Currently Offline Reputation: 3 (100%) ![]() |
so i need a new motor, but when i look for one on ebay i see that the 3sfe is a replacment. what does that mean exactly? i know the 3sfe is only a 2.0, and i do wanna boost it later, am i better off going with the 3sfe that the 5s? and how much more work would it be to drop it in? any info would be much appreciated, as i am trying to get this done ASAP.
-------------------- Your signature is not allowed on 6GC - Defgeph
QUOTE(SlickRick @ May 7, 2007 - 9:07 PM) [snapback]555147[/snapback] so i need a new motor, but when i look for one on ebay i see that the 3sfe is a replacment. what does that mean exactly? i know the 3sfe is only a 2.0, and i do wanna boost it later, am i better off going with the 3sfe that the 5s? and how much more work would it be to drop it in? any info would be much appreciated, as i am trying to get this done ASAP. dont bother. its an older, smaller version of a 5s, with less HP. -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Don't
Other than the fact the 3S has alot less power, it has no spot for a knock sensor. So your ECU will constantly be pulling timing, and you will have a CEL. -------------------- ![]() |
thanks a bunch you Presure and alltracman. I was on the verge of making a mistake then! have u seen any threads on the 4AGE swap? i seen a few but nothing that talks about the $$$ aspect of it. it would be nice if u could point me in the right direction.
QUOTE(SlickRick @ May 7, 2007 - 9:19 PM) [snapback]555158[/snapback] thanks a bunch you Presure and alltracman. I was on the verge of making a mistake then! have u seen any threads on the 4AGE swap? i seen a few but nothing that talks about the $$$ aspect of it. it would be nice if u could point me in the right direction. if you have an "S" series engine (which you do) stay away from the "A" series swaps. -------------------- Former Team 5SFTE pro member ;)
QUOTE(presure2 @ May 8, 2007 - 1:24 AM) [snapback]555160[/snapback] QUOTE(SlickRick @ May 7, 2007 - 9:19 PM) [snapback]555158[/snapback] thanks a bunch you Presure and alltracman. I was on the verge of making a mistake then! have u seen any threads on the 4AGE swap? i seen a few but nothing that talks about the $$$ aspect of it. it would be nice if u could point me in the right direction. if you have an "S" series engine (which you do) stay away from the "A" series swaps. thank u kindly... yeah i think i am just gonna stick to the 5s for now, maybe down the road a 3s. -------------------- Your signature is not allowed on 6GC - Defgeph
Lo-Fi Version | Time is now: February 21st, 2025 - 9:08 AM |
