> Engine cuts out on 7AFE, Stupid thing.
post May 8, 2007 - 2:35 PM
daphreakda
Joined Dec 3, '03
From Hamilton, MT
Hey, I have a stupid problem. My celi missfires at the slightest little bit of load. (Taking off from stop lights, passing cars, etc.) Its the 7AFE, rebuilt by a crappy company with about 25,000 on the motor. I have replaced: distributor, fuel filter, alternator, plugs, wires, cap, rotor. In addition I have checked the fuel pressure out of the rail, checked the valve gaps, ignition timing, and cam timing, all of these were in spec. Does anyone have any ideas? I would really appreciate any help. Thanks.
This post has been edited by daphreakda: May 8, 2007 - 2:39 PM
You can lead a horse to water, but there is no way your VCR will benifit from it.
post May 8, 2007 - 3:21 PM
trd94
Joined Jan 9, '05
From green springs ohio
check your compression of the motor you could have a leak , or posiably a vacuum leak in the intake manifold
post May 8, 2007 - 6:14 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
check the connections at the harnesses all over the engine for bad connections.
are you using stock plugs? if not use stock plugs.
Lo-Fi Version Time is now: April 23rd, 2025 - 7:58 PM
