new clutch advantage, what is a new clutch good for ? |
May 9, 2007 - 11:25 AM |
Enthusiast Joined Mar 4, '07 From bayville Currently Offline Reputation: 5 (100%) |
i know if its worn out, then its good to get a new one, which is what i had to do, but when you get a racing clutch, how exactly does that benefit you? i know its better for the strip so when you pop the clutch fast, it wont wear it out more and the clutch can handle it anything else really? |
May 9, 2007 - 7:40 PM |
Enthusiast Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
The benefit of a "race" aplication clutch is the holding power and the feel of the shift. The stock is a fiberous disc that is made to hold the power of the stock engine and to have soft engagements along with long life. A race series ceramic 4 puck style is made to handle a pumped up engine that has high torque and high horse power. It will not engage soft and will chew up the flywheel and pressure plate on a daily driver. If you are looking for something that feels a little stronger get a higher clamping force pressure plate with an OE style clutch plate, like Centerforce or Clutchmasters. That will give you longevity and more firmer clutch engagement.
Lo-Fi Version | Time is now: December 12th, 2024 - 11:39 AM |
