Enthusiast ![]() Joined Dec 8, '05 From South Bend / Mishawaka INDIANA Currently Offline Reputation: 0 (0%) ![]() |
I have a 96 convertable from Tennessee but now it's in Northern Indiana, and with colder weather and sometimes high humidity or rain, when I start up, the RPM's drop, the engine rumbles shakes and sputters and sometimes even shuts off. When I turn the key again, it almost always starts back up without an issue. Also, if I keep my foot on the gas, regulating the RPM's around 2k for 10 seconds or so, the rumbling goes away. The engine is a stock USDM engine with 118k miles on it and it gets regular tune ups and oil changes. Any idea what is causing this rumbling and how I may fix it.
Thanks guys! -BD |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 9, '06 From Ma Currently Offline Reputation: 1 (100%) ![]() |
Probably your ISC valve isn't opening when you start.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
QUOTE(alltracman78 @ May 9, 2007 - 11:23 PM) [snapback]555860[/snapback] Probably your ISC valve isn't opening when you start. where is that located? -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
On the bottom of the TB.
it only happens when the weather is particularly cold (around freezing and below) or sometimes when there's a lot of rain or humidity. Would the weather affect the ISC valve?
QUOTE(butterdog @ May 11, 2007 - 5:13 PM) [snapback]556621[/snapback] it only happens when the weather is particularly cold (around freezing and below) or sometimes when there's a lot of rain or humidity. Would the weather affect the ISC valve? hey i was having the SAME issue with my 7A-FE during this winter on the really cold days. i dont know what it was but i should clean my idle air valve. for about 30 seconds it would stumble and miss, then pickup and run fine. -------------------- |
Lo-Fi Version | Time is now: April 23rd, 2025 - 10:55 AM |
