> 3SGE Cams, Duration and machining
post May 13, 2007 - 12:22 AM
Alan
Joined Jan 23, '05
From Malta
Hey guy, does anyone know the stock Cam duration and lift for a 3G 3SGE, and has any one noticed the machining on the cam? where on the lobe side the cam is cut stright in half to reduce wieght on the valve train, imagine that with the Shimless bucket conversion how much wieght will be saved on the valve train.
I was thinking of machining mine for my conversion I am doing, but I need to know the stock duration and lift before I can.
Does anyone have this information?
If anyone need pics of the cams I will take some to show you!
post May 13, 2007 - 12:33 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Hey bro, just curious but what do yu got goin on? I hve a 3rd gen, and am right now in the process of rebuilding it..are you doing the same, but anywho, here is what you were looking for....
3.gen 3SGE M/T (180ps):
In: 252deg, 9.8mm lift (timing 7/65)
Ex: 240deg, 8.2mm lift (timing 53/7)
Also if you need any more help just let me know ^_^
This post has been edited by 3WayStunna: May 13, 2007 - 12:36 AM
(\__/)
post May 13, 2007 - 5:54 AM
Alan
Joined Jan 23, '05
From Malta
QUOTE(3WayStunna @ May 13, 2007 - 12:33 AM) [snapback]556980[/snapback]
Thanks man
http://www.6gc.net/forums/index.php?act=ST...t=0#entry534598
Lo-Fi Version Time is now: December 12th, 2024 - 9:36 AM
