Engine acting weird ... |
May 15, 2007 - 10:36 AM |
Enthusiast Joined May 13, '07 From riverside, ca Currently Offline Reputation: 0 (0%) |
when i start my 97 5sfe engine : sometimes it revs up and then just stalls , and other times it idls on very low RPM when it is supposed to be high ! and i had to press the gas pedal and rev it a lil bit untill it gets to normal .........whats wrong with it ? what can i do to maintina my engine and what kind of additives should i use to keep my engine running smoothly ....
May 15, 2007 - 10:50 AM |
clean out your aic air intake control valve do hicky ma bobber, check spark plugs and wires
May 19, 2007 - 12:25 PM |
OK , how do i do that ?
May 19, 2007 - 1:28 PM |
kinda of topic but i didnt want to add a new thread , i am getting 300 miles from 12 gal from my 97 convertible , is that normal ? if not then how can i improve my gas millage ?
May 23, 2007 - 3:31 AM |
Enthusiast Joined May 16, '07 From Newcastle UK Currently Offline Reputation: 0 (0%) |
QUOTE(NaderG @ May 15, 2007 - 4:36 PM) [snapback]557832[/snapback] when i start my 97 5sfe engine : sometimes it revs up and then just stalls , and other times it idls on very low RPM when it is supposed to be high ! and i had to press the gas pedal and rev it a lil bit untill it gets to normal .........whats wrong with it ? what can i do to maintina my engine and what kind of additives should i use to keep my engine running smoothly .... Sounds like it could be your idle control valve. Get it cleaned or replaced. -------------------- |
May 23, 2007 - 3:38 AM |
QUOTE(NaderG @ May 19, 2007 - 7:28 PM) [snapback]559520[/snapback] kinda of topic but i didnt want to add a new thread , i am getting 300 miles from 12 gal from my 97 convertible , is that normal ? if not then how can i improve my gas millage ? Let me work this out... For comparrison:- I filled my car the other day, cost £45. Petrol/gas is £0.939 a Litre in UK at moment, so 45/0.939 = 47.9233 Litres bought. UK Imperial Gallon is 4.54 Litres. 47.9233/4.54=10.555 Gallons I get aroung 300 miles on a full tank too so 300/10.555 = 28.4225 Mpg Average. If you want to save money, drive like an old lady, keep the roof up at all times, turn you ICE off and don't use your aircon or lights! LOL -------------------- |
May 23, 2007 - 9:00 AM |
i get 220 before filling up 12 gallons, thats bad
May 23, 2007 - 9:12 AM |
Our celicas are supposed to get better milage , so combined with my really rough-running engine , could it be something like the oxygen sensor ? and is there any HOW_TO i can use so that i can clean my ICV and oxygen sensor ?? thanks alot ppl
This post has been edited by NaderG: May 23, 2007 - 9:21 AM |
May 23, 2007 - 10:33 AM |
I have been researching and regarding to my really rough idle i came up with this :
- it could be the idle air control valve - some sensor ) oxygen , MAF) - weak engine mounts - Auto tranny problem also the car is really rough when not moving and in Drive , when i turn on my A/C the rpm drops instead of going up !! i would like someone to tell me how to clean my idle control valve , change my oxygen sensor and tell me something and the engine mount thing ( sounds like a big problem ) , how much would it cost to fix or renew ? Thanks This post has been edited by NaderG: May 23, 2007 - 10:33 AM |
May 23, 2007 - 11:00 AM |
I had the same problem with another car. First off, you've got to find the Idle control valve! I've no idea where it is on a Celi! Sometimes they get a bit cr#ppy with age. I replaced the entire unit on my old car but later discovered that I could have got it cleaned up instead.
If memory serves me, there were some vacuum hoses connected to it and a electrical multi-plug. If the celica is the same, maybe there's a leak in one of the hoses or the plug's not connected properly? I don't know, just a thought... Its gonna be one of those "trial and error" faults I think. -------------------- |
May 23, 2007 - 11:32 AM |
Enthusiast Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
300 miles is exactly where you should be on average with your 5S.
My first thought when reading your problem was that you might have an auto tranny problem. However that would pretty expensive to fix if that's the case, so try out some of those other solutions first to see if they fix the problem. OR just find a repair shop in town that will give you a free estimate and then fix it yourself after they've diagnosed the problem. -------------------- |
May 23, 2007 - 3:17 PM |
well , i kind of excluded an auto tranny problem because when i start it , it is in very low RPM and it is rough in Neutral as well , i will try and get a hold of my idle valve , i think i found a how-to but just need some more pointers , one more thing : why does my rpm drop when i turn on my A/C instead of going up ??
add: can anyone tell me how to change my oxygen sensor ?? This post has been edited by NaderG: May 23, 2007 - 3:29 PM |
May 23, 2007 - 3:34 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
usally there are two bolts holding into the ex. mani. simply unbolt them and disconnect the wire from the harness take the new one put it in rebolt it down reconnect wire and start her back up...good too go....o2 sensor's are around 70 dollars or so thou and usally if it is the o2 you will havea CEL on...but yea all farely simple.
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
May 23, 2007 - 6:25 PM |
Ok , thanks , can someone provide me with a link to a detailed how-to clean my idle air control valve ??? i dont have much experience so i need a lot of details
May 24, 2007 - 1:39 AM |
QUOTE(NaderG @ May 24, 2007 - 12:25 AM) [snapback]560988[/snapback] Ok , thanks , can someone provide me with a link to a detailed how-to clean my idle air control valve ??? i dont have much experience so i need a lot of details I'm not sure what I'd use to be honest? I live in the UK, no doubt the stuff we use over here might not be available in the states? You could use an alchohol based solution to clean it, so Methalated Spirit or whit spirit or whatever its called where you are? It might not work but its worth a try? If it is the Idle Control Valve that's faulty, you might be better off replacing it altogether? -------------------- |
May 24, 2007 - 2:12 AM |
go to the so cal meet and ill show u if not help u do it
May 24, 2007 - 12:05 PM |
Well going to the meeting would be kind of a problem for me , i have a hectic schedule and if i am not working / at classes i am studing or doing homework lol , so , where do we meet ? when ? maybe i can show up ... , also a how-to would still be great and i will be using a carb cleaner spray , for my knowledge ( however little it is ) i know this will clean it just fine ! ....also how much would a new valve cost ?
May 25, 2007 - 4:12 PM |
ok.... this post have been up for a couple of days and i still havent got the answer i need !
ALL i need is that someone walk me through or give me a link to a detailed how-to for cleaning my Idle Air Control Valve/..... Please... |
May 25, 2007 - 11:35 PM |
on my 7afe there are 4 phillips screws on the unit, which is on the bottom of the throttle body. remove the 4 screws and the unit comes off. spray and gunk out of the unit and out of the passages in the throttle body, then install it again.
May 26, 2007 - 12:51 AM |
what about the other stuff on there , there are a bunch of hoses( vacum hoses i believe ) , seleniods , the throttle spring thing and the air intake tube......honestly i couldnt even take off the air intake tube
Lo-Fi Version | Time is now: November 23rd, 2024 - 8:18 AM |
