3s gte?!?!?!?! help!, what should i do |
May 15, 2007 - 11:17 AM |
Enthusiast Joined May 14, '07 From Lexington, KY Currently Offline Reputation: 0 (0%) |
so i wanna spice up my standard 94 hatch celica and i dont want that stock 5sfe engine anymore.. i had been looking on ebay at a couple 3sgte models for around 3k.. the only thing is that i have no idea what to do After i get the motor tranny etc... special modifications to my car so i can prepare the swap yadda yadda yadda... if anyone knows please help me out asap!
thanks, Zatoichi |
May 15, 2007 - 11:41 AM |
May 15, 2007 - 1:08 PM |
what this so called clip that i keep reading.. and another thing does the 3sgte come with AWD tranny?
does anyone know where i can find a good 3s for a good price? other than ebay This post has been edited by zatoichi: May 15, 2007 - 1:10 PM |
May 15, 2007 - 2:26 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
Clip = half cut
3sgte can come with either awd or 2wd transmission. It depends on which car it originally comes from (Celica GT-Four or MR2 Turbo) -------------------- _Gary
May 15, 2007 - 4:15 PM |
ok im retarded... i dont follow "half cut" like half the st 185 car itself or... please enlighten me.
May 15, 2007 - 5:10 PM |
ok nm i did a little research..
May 15, 2007 - 9:22 PM |
keep researching. dont buy anything until you have a solid understanding of what everything is, and what needs to be done, and why.
May 15, 2007 - 11:55 PM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
spec makes a clutch that allows for ur s54 trans from ur 5sfe to be mated to the 3sgte. get teh stg 3. what it basically is is a clutch for the 3s and as such will bolt up to the 3s flywheel. but the disc has a spline count to take the 5s's s54 trans.
there are other routes to take as well such as an e153 trans from a mk2 mr2. good luck on ur research. |
Lo-Fi Version | Time is now: January 13th, 2025 - 3:12 PM |
