> Easiest engine swap
post May 15, 2007 - 12:25 PM
unionbay101
Joined May 15, '07
From El Paso, TX
HI, i just bought a 95 gt coupe and i was wondering what type of engine would be the easiest to swap the 3s-gte or the 4s-gte...?
post May 15, 2007 - 12:34 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
the 3sgte swap is simple for a GT, buy a clip, pull the harness transmission/engine etc. send the harness out to somebody like DG or tweak , they send it back complete, then its just plug and play.
the swap is only difficult when you try to rush it and do not do the proper maintenence, so do plenty of research, and remember that the work is going to be 2x as difficult with the engine in the car, so you mid as well bite the bullet and replace EVERYTHING you can think of on the engine.
This post has been edited by brianforster: May 15, 2007 - 12:35 PM
post May 15, 2007 - 12:44 PM
unionbay101
Joined May 15, '07
From El Paso, TX
thanks for your help brianforster...and put some pics of your car..i wana see the 3sgte
post May 15, 2007 - 12:45 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
3SGTE. Because there is no such thing as a 4S-GTE. There is however a 4A-GE and 4A-GZE, but not 4S.
You have a GT - meaning you have a 2.2L 5S-FE. A good rule of thumb is that it is easiest to swap in the same series engine that you have now. GT's are easier to swap S- series engines and ST's are easier to swap A-series engines. If I were to swap I would opt for a 4AGE 20V because I currently have an A- series motor (7A-FE)
The 3S-GTE will essentially drop into a GT's existing motor mounts and transmission. The only thing that will require work is the harness. If you wanted to go with any A-series you would need to change your motor mounts to those of an ST, new transmission, axles, harness, etc. This goes for ST guys swapping 3S-GTE's.
**** Photobucket
post May 15, 2007 - 12:47 PM
brianforster
Joined Mar 3, '04
From Hollywood, MD
theres my engine bay, there are might cleaner but, you asked for it smile.gif
Lo-Fi Version Time is now: January 15th, 2025 - 1:16 AM
