> knocking in the rear
post May 16, 2007 - 2:09 PM
lxarmijo
Joined May 4, '07
From Denver
when i drive my car and go over bumps both sides of my rear end knock only when i go over bumps not when i turn. i'v replaced the struts and upper strut mounts. i need help i dont want to mess up my car. can it be the stableizer bar. it has somthing to do with the suspention.HELP!!
post May 17, 2007 - 12:05 AM
CelicaGT04
Joined Nov 22, '05
From Mesquite, Texas
It might be a possibility that your end links are 1) loose and need tightening (or) 2) Old and need replacing.
post May 17, 2007 - 12:05 PM
mikew04
Joined Feb 19, '04
From austin tx
Could also be your sway bar bushings; they are only a couple of bucks each and easy to replace. Easy/cheap to replace and they are probably worn anyways...
However, in my case the clunking was caused by worn endlinks as GT04 suggested.
Lo-Fi Version Time is now: February 13th, 2025 - 3:16 PM
