> blue smoke
post May 17, 2007 - 12:00 PM
cg97
Joined Nov 30, '05
From British Columbia, Canada
so i start my car this morning, and puff, a bunch of blue smokes blows out of exhaust. now i have not noticed anything wrong with the car at all, has been running fine, recently got the oil changed, any any ideas? only happened early this morn, briefly, then it sat for 2 hours and didnt do it when i started it then. im not sure if i should just see if it happens again or ya not sure. what you guys think
post May 17, 2007 - 12:17 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
Could be a leaky piston ring or head gasket. If it's just a little, I don't think you need to be terribly concerned, but if it becomes constant (while you are driving or idling) then you want to get it looked at.
This post has been edited by Sinyk: May 17, 2007 - 12:18 PM
post May 17, 2007 - 5:06 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
valve seals, pretty common.
post May 19, 2007 - 11:54 AM
RisingSun1
Joined Sep 29, '06
From US
----- VALVE SEALS
post May 19, 2007 - 12:18 PM
6gsillyca
Joined Jan 13, '06
From UnderTheGround403
My old celica did this. 1+ for valve seals.
Fix: add some atf into your crankcase ~200 miles before you change your oil. I did this 2-3 times and problem went away. Car has been fine for almost a year now.
Lo-Fi Version Time is now: January 14th, 2025 - 7:01 AM
