> window tint
post May 17, 2007 - 2:53 PM
KaJuN
Joined Apr 12, '07
From Winkler
well, i plan on tinting my windows some time in the near future. The only question i have about the topic though, is how do you tint the rear glass? i understand you have to merge two sheets together, but has anyone done this before? I would consider getting my windows tinted profesionally, only thing is around here it's anywhere from 300-400 dollars, which i think is outrageous. If anyone has any tips, feel free to share biggrin.gif
post May 17, 2007 - 2:58 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
its one giant sheet of tint, but the hatch costs the most because the size...they shouldnt need to merge
post May 17, 2007 - 3:59 PM
Sinyk
Joined Oct 4, '06
From Kelowna, BC Canada
QUOTE(LewFX @ May 17, 2007 - 2:58 PM) [snapback]558935[/snapback]
My old car had a big hatch and the glass was angled on the sides. When it has a big angle, sometimes they use a clear grease to get the tint to stick to the glass in the curve. Our hatches aren't close to needing this thank heavens, because it looks like your glass is smeared permanently.
post May 17, 2007 - 4:11 PM
2003cbgts
Joined Feb 16, '05
From south carolina
good god.. 3-400 dollars? thats awful
post May 17, 2007 - 6:05 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
To do it with one piece and no seams takes practice. The quality brands of tint come in larger width rolls. You cut a piece oversize and place it on the outside of the back window. Using a heat gun you carefully shrink the tint in the areas where the compound curves are the tightest. Then remove the backing and apply from the inside and trim. The tint will conform to the less curved areas without bubbling.
If you can't get a wide roll you can make the seam almost invisible by having the overlap follow a defroster line.
Also make sure you buy a quality tint. The cheaper stuff will just make you mad. The good stuff is a litter thicker which makes it eaiser to work and the actuall tint is part of the plastic film. Cheap tint is a sheet of clear plastic with tinted glue. The cheap stuff is a PITA and it fades much faster and tends to change color.
I have no affiliation with this guy I'm just a happy customer. He has quality tint at reasonable prices.
eBay Tint
post May 18, 2007 - 12:48 AM
Starcraftjunkie
Joined Nov 21, '05
From Wpg, MB. Canada
3-400? holy moley.. where are you taking it?
If you feel like coming down to Ming's in Winnipeg, I might have a coupon to make it a bit cheaper.
I also recall Speed Autoglass was charging ~150-200 for Lluma with the single sheet for the hatch.
QUOTE(KaJuN @ May 17, 2007 - 2:53 PM) [snapback]558933[/snapback]
Lo-Fi Version Time is now: December 12th, 2024 - 12:42 PM
