> which boost controller???
post May 20, 2007 - 12:25 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
I just got my alcohol injection. Im working on getting that set up. I want to run about 15-16 psi of boost. I bought a turbotechnics mbc and I hate it! I cant get it to work correctly. It either boosts too high, too low, spools slowly then boost creeps and so on. Ive hooked it up several different ways and no luck. Im thinking about getting an electronic boost controller. Any suggestions? I also need to raise my boost limiter. I dont want to eleminate it though. Does anyone know if these boost cut defenders eleminate boost cut or if you can raise it slowly???? Thanks
post May 20, 2007 - 12:56 PM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
i use TwosRUs mbc and it works great. never owned a ebc so cant give u advice there. for fuel cut, the ones u buy i read will give u a 22psi or 20psi boost cut at the lowest. or u can make a fully adjustable FCD and set ur cut at ano boost level: http://toymr2.tripod.com/fcd.html that'll show ya how to make one for under 20 bucks. i did it and it works fine.
bboy
post May 21, 2007 - 6:27 AM
2slow2nervous
Joined Aug 25, '06
From HAMILTON NJ
i have a hulman mbc and it works great. I have no probs with it and picked it up for under 100.00. Spools quick always acurate.
post May 21, 2007 - 9:25 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
I just bought a used blitz EBC for $200 type R.
post May 29, 2007 - 1:13 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
QUOTE(BBoYRuGGeD @ May 20, 2007 - 10:56 AM) [snapback]559712[/snapback]
bboy
X2. I've got the twosrus one on my MR2, and it's great.
This post has been edited by 94GT: May 29, 2007 - 1:14 AM
post May 29, 2007 - 8:33 AM
GTSOwner
Joined Sep 28, '06
From Montreal, QC, Canada
Used to have the turbosmart boost tee. Fantastic.
post May 29, 2007 - 8:57 AM
I used a Joe P mbc for awhile and found it excellent.
I'm now using an Apexi AVCR
post May 29, 2007 - 9:17 AM
Kadett
Joined Mar 17, '05
From The Netherlands
New HKS EVC VI boost controller has probably the solution of your problem.
post May 29, 2007 - 9:41 AM
i have a greddy type-s. works great and very simple to use.
post May 30, 2007 - 10:54 PM
eggman40
Joined Aug 17, '04
From California
I use a Turbo XS dual stage boost controller. Its a mbc but there are two of them which can be controled at the flick of a switch between two presets. I have mine set at 8psi and 15psi.
I love having the peace of mind of a MBC, and with this one, theres no need to get out of the car to change the setting wink.gif
http://www.discountpowerparts.com/catalog/...roducts_id=1288
post Jun 1, 2007 - 8:50 AM
CilverSeliST205
Joined Nov 3, '05
From Chicago Suburbs
QUOTE(Supersprynt @ May 29, 2007 - 9:57 AM) [snapback]562532[/snapback]
Do you like it? is it worth the price? i know i would have to splice into some ecu wires but thats not a problem. Did you test out any features yet?
QUOTE(tufy @ Jul 19, 2006 - 7:40 AM) [snapback]458074[/snapback]
i dont drive fast, i just fly low
post Jun 1, 2007 - 11:18 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(toyotacrazy @ May 21, 2007 - 9:25 AM) [snapback]559982[/snapback]
I love my blitz type R. Its simple to use once you mess around with the functions for a while. It has some nice features like overboost warning and overboost protection.
Lo-Fi Version Time is now: January 12th, 2025 - 8:50 AM
