Possibly another solution to the E153 axle problem, Anyone know about the E56 trans |
May 20, 2007 - 10:20 PM |
Enthusiast Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
Guys,
Did some research, and apparently the transmission that comes with the 94+ SS2 Celica (the one with the super-strut) is not a S54, but an E56 transmission. I've known about this trans for a couple of years now, but I never really thought anything of it til now - this is an E series trans mated to a 3S in a 6G gen FWD Celica!!! What's the possibility that the stock axles for this car would fit the MR2's E153 trans - giving us the perfect length axle? I've swapped between the super-strut and standard suspension on my car, and I can say that the hub placement is the same - so that wont be an issue. Now the part that worries me - this trans is also offered in other (non performance) cars ,though with different gearing and such. A few of these cars are available stateside: 88-90 AE95 Corolla 90-93 AE95 Corolla wagon. 95+ AE103 Corolla 94+ SXA Rav 4 If I get some time, I may go out and pick up an axle from one of these cars and see if it will fit the MR2's splines. If it works, I'll see what pricing Jeff @ Champion Toyota can get. Here are the part numbers if anyone is interested: drive shaft, RH : 43410-20690 SS2 Celica w/SSS drive shaft, RH: 43410-20700 SS2 Celica w/SSS w/ABS This post has been edited by scothaniel: May 20, 2007 - 10:20 PM -------------------- Scott
West Michigan |
May 21, 2007 - 5:17 AM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
what engine is this mated with and where is the car originated from? 94+ SS2 Celica (the one with the super-strut)
May 21, 2007 - 8:44 AM |
JDM / European model with a 3SGE (non-beams).
West Michigan |
May 21, 2007 - 12:59 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
'88-'91 V6 5-speed Camry axles fit perfectly for my 3s-gte/E153 swap in My Camry. That car uses an E52 transmission (the V6 auto axles also work, but that's beside the point). I can almost guarantee those axles will work perfectly for you guys. As long as you get the correct stock LSD vs. non-LSD axles, any E-series 2WD transmission axles are compatible at the transmission side.
The next worry would be the price! -Charlie -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
May 21, 2007 - 3:47 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
91 Camry axles will not fit, the splines are different and will not fit in the hubs.
May 21, 2007 - 7:21 PM |
Enthusiast Joined Jan 27, '03 From st.lucia Currently Offline Reputation: 0 (0%) |
all you have to do is change the outer c.v. joints and they should work.
This post has been edited by 1900: May 21, 2007 - 7:21 PM |
May 21, 2007 - 10:33 PM |
Providing they are the correct length.
West Michigan |
May 22, 2007 - 1:42 PM |
QUOTE(Rjb23 @ May 21, 2007 - 1:47 PM) [snapback]560097[/snapback] 91 Camry axles will not fit, the splines are different and will not fit in the hubs. -Charlie PS. Are you sure about the hubs? My Camry axles pop into the ST205 front hubs I have laying around (at least, I think they do?). Either way, they are probably the wrong length as the ST20x is wider than my car. -------------------- 2003 Subaru WRX Wagon
May 22, 2007 - 2:52 PM |
I picked up the camry outer axles before any they were too long and the splines didn't fit the 205 hubs. The inner axles must be shorter on the Camry then.
LSD may be an issue, though I think it only effects the LH side axle. -------------------- Scott
West Michigan |
May 22, 2007 - 3:58 PM |
Not the Camry axle debate again... The older, 1990 or so, Camry outers will fit the ST204. The newer 1994+ Camry outers will not because they are too big.
-------------------- Project ST204.5 99.88946% complete... |
May 22, 2007 - 10:02 PM |
QUOTE(WannabeGT4 @ May 22, 2007 - 1:58 PM) [snapback]560521[/snapback] Not the Camry axle debate again... The older, 1990 or so, Camry outers will fit the ST204. The newer 1994+ Camry outers will not because they are too big. -------------------- 2003 Subaru WRX Wagon
May 23, 2007 - 6:01 PM |
QUOTE(WannabeGT4 @ May 22, 2007 - 8:58 PM) [snapback]560521[/snapback] Not the Camry axle debate again... The older, 1990 or so, Camry outers will fit the ST204. The newer 1994+ Camry outers will not because they are too big. Not true, It may be 93 or newer, the year I tried were either a 91 or 93. The splines were to big to fit in the hub. |
May 24, 2007 - 7:54 AM |
QUOTE(Rjb23 @ May 23, 2007 - 6:01 PM) [snapback]560983[/snapback] QUOTE(WannabeGT4 @ May 22, 2007 - 8:58 PM) [snapback]560521[/snapback] Not the Camry axle debate again... The older, 1990 or so, Camry outers will fit the ST204. The newer 1994+ Camry outers will not because they are too big. Not true, It may be 93 or newer, the year I tried were either a 91 or 93. The splines were to big to fit in the hub. I don't know the exact years. I know I've read of at least 3 people that have used the older 1990 or later camry axels. -------------------- Project ST204.5 99.88946% complete... |
May 24, 2007 - 3:00 PM |
Has anyone tried the Rav 4 or Corolla all-trac wagon axles?
West Michigan |
May 24, 2007 - 10:03 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(Rjb23 @ May 21, 2007 - 1:47 PM) [snapback]560097[/snapback] 91 Camry axles will not fit, the splines are different and will not fit in the hubs. Not true, i change my axel two days ago, and i got a 91 v6 camry axel. It worked perfectly. The 92+ years are A) too long B) and have Fatter Splines that will not fit into the 6gc hub. I am 100% this is accurate. My set up: 92 mr2 non lsd tranny - E-153 92 mr2 Inner axles or half shafts 91 V6 Carmry outter axles set up works perfectly. Also just so you know 90 and 91 v6 camry axle is the same thing QUOTE(1900 @ May 21, 2007 - 5:21 PM) [snapback]560206[/snapback] all you have to do is change the outer c.v. joints and they should work. Too much work, go with my set up its way easier and effective. |
May 24, 2007 - 11:18 PM |
And this requires no spacers to work, unlike the MR2 / Celica All-trac combo?
West Michigan |
May 24, 2007 - 11:47 PM |
QUOTE(eggman40 @ May 24, 2007 - 8:03 PM) [snapback]561335[/snapback] Also just so you know 90 and 91 v6 camry axle is the same thing '88-'91 V6 Camry axles (auto or manual) are all the same. -Charlie -------------------- 2003 Subaru WRX Wagon
May 25, 2007 - 12:07 AM |
I'll tell you this much, I wish I never went E153. This thing has been such a nightmare.
May 25, 2007 - 3:27 AM |
Enthusiast Joined Jan 23, '05 From Malta Currently Offline Reputation: 2 (100%) |
I WANNA DO THE E153 SWAP BUT I HAVENT READ ONE THRED THAT SAYS THE COMPLETE SWAP WITH A 3sgte FWD CONVERSION TO THE E153, DIDNT ANYONE DO A PROPER SWAP SO FAR?
THE BEST I SAW IS THIS 92MR2 TRANNY WITH INNER HALF SHAFTS 91 V6 CAMRY AXLES (OUTER HALFSHAFTS AND AXLE) WHAT OTHER CONVERSION IS NEEDED? -------------------- |
Jun 6, 2007 - 1:42 AM |
QUOTE(scothaniel @ May 24, 2007 - 9:18 PM) [snapback]561372[/snapback] And this requires no spacers to work, unlike the MR2 / Celica All-trac combo? if you are reffering to me than no, you do not need a spacer of anykind. Just the combo posted above |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:42 AM |
