turbo upgrade help |
May 21, 2007 - 7:54 AM |
Enthusiast Joined Aug 25, '06 From HAMILTON NJ Currently Offline Reputation: 1 (100%) |
what turbo is the best choics in upgrading from the ct26 on a 2nd gen 3sgte? Looking to do and need some info on doing so.
May 21, 2007 - 8:58 AM |
depends on your goal and what you want out of the car. the sky is the limit.
have you tried turning up the boost? the ct26 should keep you happy for a while with just a boost controller. how many psi is your car at now? -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 21, 2007 - 9:01 AM |
yep i turned up my boost and i am between 12-13 rite now. I am very happy were it is but i want more lol. Dunt wanna go ne more than that dunno if i can damage nething plus i heard that i will just get a boost cut off neways? So i was looking to do whole fuel system upgrade, external wastegate and ugrade turbo.
This post has been edited by 2slow2nervous: May 21, 2007 - 9:01 AM |
May 21, 2007 - 10:06 AM |
so try 14psi next. trust me, the ct26 has a lot more to give you then what your getting right now.
May 21, 2007 - 10:22 AM |
ok i was looking into the ct26 upgrades? Were do u get the kits to upgrade them and is that something i could do myself or should i get a shop to do for me?
May 21, 2007 - 10:58 AM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(2slow2nervous @ May 21, 2007 - 8:22 AM) [snapback]559990[/snapback] ok i was looking into the ct26 upgrades? Were do u get the kits to upgrade them and is that something i could do myself or should i get a shop to do for me? http://www.atsracing.net/turbochargers_and_kits.htm ats has a few options. Looks like they have ct-26 upgrades, and they have their own ct-27 which is just a ct-26 rebuilt to their own specs. Hope this helps. |
May 21, 2007 - 11:47 AM |
Enthusiast Joined May 20, '07 Currently Offline Reputation: 0 (0%) |
QUOTE(2slow2nervous @ May 21, 2007 - 12:54 PM) [snapback]559960[/snapback] what turbo is the best choics in upgrading from the ct26 on a 2nd gen 3sgte? Looking to do and need some info on doing so. you wouldnt want to sell your downpipe would you? or what about your stock injectors? sorry forgot i also need your oil pan if you planed to sell these items? This post has been edited by 91celica_gts: May 21, 2007 - 12:01 PM |
May 21, 2007 - 6:12 PM |
QUOTE(2slow2nervous @ May 21, 2007 - 11:22 AM) [snapback]559990[/snapback] ok i was looking into the ct26 upgrades? Were do u get the kits to upgrade them and is that something i could do myself or should i get a shop to do for me? only ct26 upgrade worth while is the ct27 or buy a used ct20b. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 21, 2007 - 6:49 PM |
Enthusiast Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) |
QUOTE(lagos @ May 21, 2007 - 10:06 AM) [snapback]559987[/snapback] so try 14psi next. trust me, the ct26 has a lot more to give you then what your getting right now. lagos.......arent you running like 16-17 psi with the water injection? Im sure if he got WI and cranked it up to 16 it would keep most content for a while. mine pulls nicely at 12psi |
May 21, 2007 - 7:21 PM |
QUOTE(toyotacrazy @ May 21, 2007 - 7:49 PM) [snapback]560186[/snapback] QUOTE(lagos @ May 21, 2007 - 10:06 AM) [snapback]559987[/snapback] so try 14psi next. trust me, the ct26 has a lot more to give you then what your getting right now. lagos.......arent you running like 16-17 psi with the water injection? Im sure if he got WI and cranked it up to 16 it would keep most content for a while. mine pulls nicely at 12psi yeah... thats why im saying that the ct26 has a lot more to give him. he made about 180hp on the dyno at around 8psi iirc... and my car is at 247hp270tq at 16psi with WI... so that just goes to show how much more power you can gain without buying a new turbo. dont get me wrong tho .. the ct26 is limited, but it should be more then enough to keep someone happy for a lot longer then a month after their swap. This post has been edited by lagos: May 21, 2007 - 7:23 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 21, 2007 - 7:38 PM |
QUOTE(lagos @ May 21, 2007 - 7:21 PM) [snapback]560207[/snapback] QUOTE(toyotacrazy @ May 21, 2007 - 7:49 PM) [snapback]560186[/snapback] QUOTE(lagos @ May 21, 2007 - 10:06 AM) [snapback]559987[/snapback] so try 14psi next. trust me, the ct26 has a lot more to give you then what your getting right now. lagos.......arent you running like 16-17 psi with the water injection? Im sure if he got WI and cranked it up to 16 it would keep most content for a while. mine pulls nicely at 12psi yeah... thats why im saying that the ct26 has a lot more to give him. he made about 180hp on the dyno at around 8psi iirc... and my car is at 247hp270tq at 16psi with WI... so that just goes to show how much more power you can gain without buying a new turbo. dont get me wrong tho .. the ct26 is limited, but it should be more then enough to keep someone happy for a lot longer then a month after their swap. well, its good to know that 8 psi is around 180 hp. and 16 psi is about 240 hp. I went to the track and ran 8 psi and only ran a 15.0 1/4 mile . I wasnt too proud of this. Thats why I ordered the ebc, the mbc wouldnt stay consistant so I turned it down. plus the synchros in this trans suck! Im going to try some synchromesh and keep my fingers crossed. |
May 21, 2007 - 7:51 PM |
just from my own ass dyno ... at 8psi the car just feels like a dog. but still a hell of a lot better then the 5sfe. at around 10psi ... its quick. 13psi it starts to come alive...and 15-16psi .. it screams. you just have to make sure you have the tools to monitor things correctly as you keep turning up the boost, because the more power you make, the more risk there is of something going wrong.
May 22, 2007 - 10:56 AM |
ok ok i gotcha so keep the ct26 and work with it for now. Now i never looked into wi or anything like that how does it work?? Were can i get it?? Maybe could u install it?
May 22, 2007 - 11:01 AM |
QUOTE(2slow2nervous @ May 22, 2007 - 11:56 AM) [snapback]560412[/snapback] ok ok i gotcha so keep the ct26 and work with it for now. Now i never looked into wi or anything like that how does it work?? Were can i get it?? Maybe could u install it? take things one step at a time. learn about how things work and why, and try to do your own work to try to learn as much as you can about your car. then when your ready, youll know if something like water injection is the way you want to go. google "water injection". -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 22, 2007 - 11:06 AM |
alright sounds good.
May 22, 2007 - 11:14 AM |
i just read on that wi and i like were its going!!
May 22, 2007 - 1:59 PM |
Enthusiast Joined Jun 30, '06 From West Windsor NJ, USA Currently Offline Reputation: 14 (94%) |
Yur new bestfriend
-------------------- --------------------------------私は銀行に漂う,TRD Inspired |
May 22, 2007 - 2:17 PM |
QUOTE(Daftboy @ May 22, 2007 - 1:59 PM) [snapback]560480[/snapback] Yur new bestfriend |
May 22, 2007 - 4:40 PM |
smurf piss FTW.
its good stuff. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Lo-Fi Version | Time is now: December 4th, 2024 - 1:56 AM |
