> Turbo Manifold
post May 22, 2007 - 11:41 AM
fran
Joined Apr 28, '07
From Venezuela
Hello guys!... im in a proyect with an ST202 with a 3SGE engine, the question is that the engine block its the same that the mr2 or the celica all-trac(3SGTE)... I need to buy a good manifold & i dont find manifolds or turbo kits for my 3SGE... Anyone can help???
THX.... Fran
post May 22, 2007 - 10:51 PM
Gary
Joined Aug 28, '04
From FLA USA
Stock 3sgte manifold should be good enough for most applications.
What is your power goal? What turbo you will be using?
_Gary
post May 24, 2007 - 4:05 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
good point gary...i think you have a 3rd gen fran, so if i were you, try looking for a 3rd gen 3sgte, or any 3sgte from a celia within the years of 1995+, and they should mate up fine...if you want to be catious get one from a junkyard or on ebay and try that first...but there are also alot of aftermarket manifolds out there, and just like what gary said, depending on your goals and cash, determines which one would be best for you....but anywho, try the mani from a used 3sgte first if you have the cash...i cant say that i have personally done it before, but many ppl have shown it work...anywho, good luck bro ^_^
(\__/)
post May 27, 2007 - 11:11 AM
fran
Joined Apr 28, '07
From Venezuela
I will use t3/t4 obx turbo with the obx turbo manifold but i dont know if the turbo manifold will work in my 3SGE (ST202)... Because the kit its for Mr2 or 3SGTE, i ear that the manifold its the same for the celica, mr2 & celica all-trac... i dont know if that its truth :S, anyone knows? :S... i ear that the internals are the same for the mr2-celica all-trac- and celica (ST202)
My project for the engine will be around of 350-400HP
I need to kwon if the engine internals for the 3SGTE or the MR2 are the same for my engine (3SGE) 6generation celica (ST202) with a 2.0L 16 Valve (3SGE) N/A...
post May 27, 2007 - 1:19 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Shortblock is identical for the GE and GTE
post May 27, 2007 - 7:24 PM
fran
Joined Apr 28, '07
From Venezuela
I see I see!... do you know of the rods are the same that the mr2 or 3sgte??? i find pistons & rods all forged, but are for MR2 or 3SGTE and i dont know if they works on my 3SGE...
Thanks dudes!
post May 27, 2007 - 7:27 PM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(fran @ May 27, 2007 - 12:11 PM) [snapback]562032[/snapback]
Those things are crap.
Do it the right way and you will not be sorry.
_Gary
post Jun 4, 2007 - 4:51 PM
scothaniel
Joined May 1, '03
From Michigan
Rods are the same for all 3S motors, and they are extremely strong. Unless you are planning for 500+ HP, or your trying to add power and stay in a particular racing class / division, there's no need to upgrade the rods.
The 3SGTE and 3SGE pistons are interchangeable. I put stock (st185) 3SGTE pistons in my st202 3SGE.
For a 3rd gen 3SGE (st202), you'll need the ST205 manifold. The ST185 and similar MR2 manifolds wont work. If you can find a stock 205 manifold, it will be much stronger then the ebay stainless ones. Check www.mr2oc.org for used 3rd gen manifolds.
Scott
West Michigan
post Jun 7, 2007 - 11:24 PM
fran
Joined Apr 28, '07
From Venezuela
Thank!... do anyones know where i can find good turbo kits for my 3SGE???... y see the exhaust maniolf of my engine and its the same that the 3SGTE... The thing its the durability of that manifolds on ebay :S.... the problem is where i live, i must bring all these parts on plain or ship... take sooo long in ship! but dont care!, the thing is that i cant see the manifolds in front of my if i cold see it i can have an idea of hoe could strong be those manifolds... any good brands??? good turbo kit???... MR2 Kits will works perfectly in my car???
So many qustions :S.... Thanks for your help dudes (Y) wink.gif smile.gif
post Jun 7, 2007 - 11:35 PM
fran
Joined Apr 28, '07
From Venezuela
soon i must remake my engine.... my car have 230.000 KM... so i can just put new rod and new pistons (forged)... the crankshaft its strong enought? or i must search for another one??? how about the oil pump? good lubrication?
i dont know how its my rods so i think that its better to replace it for new ones... i see eagle rods with JE pistons, pistons give me a 9.0:1 compression rate... so i think that its good for 18 PSI low and 25 high.
im thinking to put 400HP+50HP(nitro)(meibe mooore) on my celica, i want can road it on streets too and can go travel with it without problems.
Anooother problem that i have its the ECU.... i dont know how i can use for fuel manegement, maibe aditionals inyectors with an UNICHIP?...
Or 1000cc inyecors? meybe less? :S
post Jun 8, 2007 - 1:37 PM
scothaniel
Joined May 1, '03
From Michigan
If your having a shop rebuild the engine, have them inspect the rods. If they are in good condition, don't bother to replace them. Seriously, the rods in the 3SGTE is bigger and stronger then one's in a 350 Chevy motor. If you need further info, just talk to the engineers at Carrillo ( http://www.carrilloind.com ), they are the one's who first told me not to bother with upgrading.
The stock crank is strong enough for sure. I only know of a couple of people who've upgraded the oil pumps.
ECU - Check out the apexi power-fc, as they have a 3SGE version available. It may offer a plug and play solution that will handle boost.
Turbo kits - ST205 Celica kits will work best. Some MR2 manifolds work and some dont (hit the alternator). Greddy TD06-L2 would get you close to 400HP.
Scott
West Michigan
post Jun 9, 2007 - 12:14 PM
fran
Joined Apr 28, '07
From Venezuela
My engine its 3SGE not 3SGTE... But i was saying on internet pages and its the same, except by the intake manifold & exhaust manifold, but the alternator its in the same place, the direction oil package its in the same place, the adiator package its in the same place... How i could know wath manifold work`s? i saw various manifolds from ebay, OBX, Greddy, and some other that no have specific brand but are stainless steel.
I see turbo kit with turbo manifold, turbo T4 (Garrett), Weastgate 38mm and downpipe... My afraid its buy that stuff and later dont work in my car :S
post Jun 9, 2007 - 12:22 PM
Kadett
Joined Mar 17, '05
You would also need a 3S-GTE oil pan since it has a seperate oil feed/drain line.
I wouldn't touch those Ebay stainless steel manifolds.
@Scoth: How can you compare a V8 300-350bhp to a L4 250bhp concerning rods. Per rod the L4 needs stronger rods then the V8 because it needs to hold more power.
post Jun 9, 2007 - 1:13 PM
scothaniel
Joined May 1, '03
From Michigan
Very true. I'm just saying the 3S's rods are very strong. The comparison to the V8 rods is only because they were laying on the table next to me.
The alternator on the MR2 is located where the power steering pump is on the Celica or Curren. Therefore, there is more space for the exhaust manifold on the MR2. Some aftermarket manifolds for the MR2 will hit the alternator if installed on the Celica. It's not an issue of 3SGE versus 3SGTE, but rather Celica versus MR2.
Actually, the oil pan's are the same, only the port for the oil return is not drilled out on the 3SGE. He'll just need to drill it out, and buy the oil return hose (part number 15491-88480). Another option would be to drill and tap, then use a AN fitting.
Scott
West Michigan
post Jun 9, 2007 - 1:47 PM
6strngs
Joined May 12, '06
From Wilmington, NC
my friend has a chevy truck with a 350 in it and he threw a rod a couple months ago. so I don't think comparing to them is the best comparison. lol
post Jun 9, 2007 - 2:16 PM
fran
Joined Apr 28, '07
From Venezuela
i see various exhaust manifolds for my car.... The ebay stainless steel manifold dont look good :S... anyone know a website where i can find good items for my 3sge? any manifold ho works on my car?... ill send picks of my engine so you can see!
post Jun 9, 2007 - 4:49 PM
Kadett
Joined Mar 17, '05
The only reliable one's I know of are C-one and Aussie. Aussie = 900 USD shipped (according to their site) and C-one would be above 1000 USD I'd quess.
post Jun 10, 2007 - 11:04 AM
scothaniel
Joined May 1, '03
From Michigan
I have a 3rd gen 3SGE in my car right now (turbo'd) and another in the garage that I use for modeling parts.
This guy has a stock 3rd gen exhaust manifold for $50 shipped:
http://mr2oc.com/showthread.php?t=246898&a...xhaust+manifold
They you could use any of these kits:
http://www.atsracing.net/turbochargers_and_kits.htm
Or any T3 based turbo using an adapter
Here's a greddy 3rd gen manifold:
http://cgi.ebay.com/ebaymotors/Trust-TD06-...sspagenameZWDVW
And here's the turbo that would fit it:
http://cgi.ebay.com/ebaymotors/OBX-T67-25G...sspagenameZWD1V
Lots of options.
Scott
West Michigan
post Jun 10, 2007 - 12:46 PM
fran
Joined Apr 28, '07
From Venezuela
i see!... i found on ebay one kit and look pretty good! its and OBX turbo with OBX Manifold, life guarantee on manifold turbo 1 year guarantee :
http://cgi.ebay.com/ebaymotors/OBX-91-95-M...1QQcmdZViewItem
Thre u can see it, any suggestion?
post Jun 11, 2007 - 11:52 AM
scothaniel
Joined May 1, '03
From Michigan
Doesn't look like a 3rd gen manifold. Ask if it fits the 90-93 ST185 Celica. If so, then it WILL NOT work with your car
Scott
West Michigan
Lo-Fi Version Time is now: November 23rd, 2024 - 9:31 PM
