> 2.25 or 2.5 inch piping?, neeed help
post May 22, 2007 - 1:00 PM
celitrd
Joined Dec 14, '06
From california , san leandro
alrite so in about a week i'm bouta do a custom catback with my muffler i bought [n1 style muffler] i dont know what piping to do either 2.25 or 2.5 because i heard if my piping is too big i will looose low end power so i'm wondering what is the piping on the greddy sp whats you guys results with a 2.25 and 2.5 piping results?
post May 23, 2007 - 3:00 AM
Racer_J
Joined May 16, '07
From Newcastle UK
QUOTE(celitrd @ May 22, 2007 - 7:00 PM) [snapback]560459[/snapback]
Is your car N/A? If it is, you'll need the smaller bore piping, 2.25" or so I'm told or you will lose power. If it's turbo'd, go for 2.5" or larger.
post May 23, 2007 - 9:25 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
2.25" will be best for you. If you have serious plans of swapping either 3S-GTE or 4A-ZGE I would say 2.5", but since it looks like you have some basic bolt-ons on the 7A-FE you should look into the 2.25".
**** Photobucket
post May 23, 2007 - 9:58 AM
Yes 2.25
post May 23, 2007 - 10:13 AM
massbrandon
Joined Mar 6, '06
From massachusetts
On my GT I went with 2.5 inch and I love it.
post May 23, 2007 - 11:27 AM
GTS13
Joined Apr 14, '06
From Vancouver, WA
GTs can do 2.5 no problem, but with an ST you don't want to go any larger than 2.25.
post May 23, 2007 - 12:44 PM
Seeing as alot of Alltracs go 2.5 it's a bit overkill for a 135hp car with very little benefit for the extra cost.
post May 24, 2007 - 9:36 PM
Eds94GT
Joined May 15, '07
From Tyler Tx
I had about the same ? but I have a pretty stock GT for now but plan to go turbo, how would the car act if I put 3" from the header and did a Y past the rear with 2.25 duals? I just want to get the exhaust done for now but do not want to pay twice for it.
post May 24, 2007 - 10:40 PM
That'd be pretty pointless.
post May 24, 2007 - 10:46 PM
jesterwr217
Joined Feb 27, '07
From cape coral/ft myers florida
im running 2.25 with a turbo and it works perfectly
BOOST GETS YOU LAID!!!!
post May 24, 2007 - 10:51 PM
Eds94GT
Joined May 15, '07
From Tyler Tx
Why would it be pointless? Turbos love 3" exhaust or are you talking about the Y, or the fact that duals look good. Do you think that I would loose power do to the 2.25 pipe after the Y, correct me if I am wrong but the two 2.25" = 4.5" which means more flow!
post May 24, 2007 - 10:53 PM
You'd be better off just doing 3'' all the way back. The chassis doesn't allow you to really do a Y pipe...one pipe makes almost a L turn, ruining any good flow.
post May 24, 2007 - 11:04 PM
Eds94GT
Joined May 15, '07
From Tyler Tx
I see your point. I do all of my own work and my family owns a machine shop so the engine that is in the works will pust the limits of the 2.2 block. The engine will be far from stock as well as the turbo. I just know that I will need to get rid of all that extra exhaust.
post May 25, 2007 - 9:23 AM
jesterwr217
Joined Feb 27, '07
yea dont bother y piping it into dual exhaust because your going to loose power because our engine dont put out enough air flow and i wouldnt do more than 2.5 unless you seriously planning on 300+ hp my suggestion would be find a shop that will do your entire exhaust i found one that custom made mine straight pipe the whole way back for 150 bucks
post May 28, 2007 - 12:02 AM
6strngs
Joined May 12, '06
From Wilmington, NC
celitrd - where are you getting your exhaust done? I need to find a place in the area that can make me a 3" turbo-back.
Lo-Fi Version Time is now: November 27th, 2024 - 2:12 PM
