> dream swap?
post May 22, 2007 - 4:38 PM
Eds94GT
Joined May 15, '07
From Tyler Tx
What is the best motor to put in a 1994 GT besides the 2.0 turbo? Does toyota have any newer motors that would make the king of swaps? I want to make alot of power with turbo and nos and am planing to put this in a GT4 clone.
post May 22, 2007 - 5:39 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Eds94GT @ May 22, 2007 - 4:38 PM) [snapback]560534[/snapback]
I think the king of all swaps would be an AWD 1MZ-FE v-6 with a TRD supercharger. That sounds awsome to me! Plus its a newer motor than the 3sgte
post May 22, 2007 - 5:46 PM
Eds94GT
Joined May 15, '07
From Tyler Tx
I was thinking more in the lines of a newer 4cyl. A v6cyl would add waight and engine cooling problems and alot of extra fab work.
post May 22, 2007 - 5:49 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(Eds94GT @ May 22, 2007 - 5:46 PM) [snapback]560547[/snapback]
The weight shouldnt be too much of an issue considering the benefit. But the fabrication and amount of work involved, sure could detour most from wanting to take on this type of swap.
post May 22, 2007 - 8:33 PM
alltracman78
Joined Aug 9, '06
From Ma
QUOTE(toyotacrazy @ May 22, 2007 - 5:39 PM) [snapback]560544[/snapback]
Actually the newest version of the 3S is newer than the 1MZ.
There is a newer larger MZ though. The 3MZFE. It's a 3.3.
But the King of V6 swaps would be the 2GRFE.
3.5L dual VVTi.....
And the Lexus versions have direct injection available...
It's even available in AWD config on the Rav4.
Dunno if it would fit in a 6th gen though.
post May 22, 2007 - 9:33 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
isint the 3m actually lighter than the 3s?
post May 22, 2007 - 10:16 PM
alltracman78
Joined Aug 9, '06
From Ma
I believe the 1MZ is. Or right about the same weight.
I don't know if the 3MZ is as well.
post May 22, 2007 - 11:00 PM
Gary
Joined Aug 28, '04
From FLA USA
Try 3UR-FE if you have enough space.
Or be realistic and stick with 3sgte.
With proper modifications, it will make enough power more than you need.
_Gary
post May 22, 2007 - 11:51 PM
IPB Image 500+whp RWD 3sgte
This post has been edited by playr158: May 22, 2007 - 11:51 PM
post May 23, 2007 - 1:21 AM
Hanyo
Joined Aug 16, '03
From Bay area
I would like an M3 type thing..
Big V8 rwd.
post May 28, 2007 - 6:33 AM
celicaST
Joined Jun 23, '05
QUOTE(alltracman78 @ May 22, 2007 - 9:16 PM) [snapback]560652[/snapback]
you are right, the 1mz is lighter. the 3mz should be as well since it is essentially just a bored out 1mz
post May 28, 2007 - 9:11 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(celicaST @ May 28, 2007 - 6:33 AM) [snapback]562221[/snapback]
plus it has a plastic intake plentium
post May 28, 2007 - 9:44 AM
Kadett
Joined Mar 17, '05
From The Netherlands
3S-GTE mounted lengthwise with FMIC and RWD using the ST205 rear suspension.
Using the 6 speed IS200 3S-GE tranny to transfer power from the engine.
post May 29, 2007 - 2:18 PM
HypnoToad
Joined May 3, '07
From Georgia,USA
my dream swap in a celica would be a 20B and RWD it.
1997 Toyota Celica Limited Edition ST
post Jun 4, 2007 - 3:06 AM
airfron
Joined Jul 31, '05
From Southern California
since people are throwing out some crazy ideas.
two turboed hayabusa engines powering an awd transmission...
no? ok how about the bowdown.gif 2gr-fse?
how deep are your pockets??
post Jun 4, 2007 - 10:09 PM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(airfron @ Jun 4, 2007 - 3:06 AM) [snapback]564639[/snapback]
post Jun 4, 2007 - 11:52 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
dream swap:
3VZ-FE
ST205 AWD
Turbo
900 AWHP
*drools*
carTest software says:
my 0-60 would be 2.23 seconds
1/4 mi would be 9.3 @ 147
8.8 mpg lol
max Gs 3.5!
comparison GT:
8.08 0-60
1/4 mi 16.1
29.8 mpg
max Gs 0.55!
Comparison ST:
8.71 0-60
1/3 mi 16.6
35.4 mpg
max Gs 0.52
post Jun 5, 2007 - 9:41 PM
SinisterWhisper
Joined Nov 14, '04
wow take two hayabusa engines when you can just get a v8 with hayabusa heads?
post Jun 5, 2007 - 9:52 PM
slvr_celica_GT_8...
Joined Jul 18, '06
From plymouth, MA USA
a twin turbo inline 4 lol, with a slit header running into 2 turbos
IPB ImageIPB ImageIPB Image
Lo-Fi Version Time is now: February 17th, 2025 - 9:39 AM
